Author Topic: car is "missing" -HELP STILLURGENTLY NEEDED  (Read 5979 times)
Offline martziniuk
Re: car is "missing" a beat or two-UPDATE 13/7/11
« Reply #15 on: July 13, 2011, 11:14:50 pm »
I read it over on the Yank forums lol. There maybe a few more ponies to squeeze out yet then  :party:
Offline 56OctyVRS
  • -Receive: 72
« Reply #16 on: July 14, 2011, 09:27:10 am »
You cant beat more horse power :happy2:
Offline matsu
  • -Given: 78
« Reply #17 on: July 14, 2011, 03:25:50 pm »
i have ordered the heat tape which i will wrap the area around the maf. and also the heat shield and underneath the engine cover so nicely adapted by big AL.
and i will spraying the engine cover/the rest of the intake pipe and the heat shieldwith high temp engine paint.
so fingers crossed it sorts it all out
thanks for everyones help and input.
matsu
Offline liver
« Reply #18 on: July 14, 2011, 03:26:39 pm »
have you got a link to the heat tape?
Offline matsu
  • -Given: 78
« Reply #19 on: July 14, 2011, 05:19:00 pm »
on previous page buddy  :happy2:
matsu
« Reply #20 on: July 14, 2011, 05:57:05 pm »
When I had my intake on I fitted the heat shield and just wrapped the pipe with exhaust wrap.  Equally you can buy heat shield tape and wrap that around.  I recently put heat shielding tape under my OE engine cover that reflects upto 90% of the radiant heat.  It cost me £16 for 10 meters and that would be more than enough to completely wrap the pipe.
I puchased mine from here http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=300563370760&category=38786&_trksid=p5197.c0.m619
Any pics?  :party:
Offline 56OctyVRS
  • -Receive: 72
« Reply #21 on: July 14, 2011, 09:37:36 pm »
I will post some up tomorrow for you guys :happy2:
Offline matsu
  • -Given: 78
« Reply #22 on: July 16, 2011, 10:23:02 am »
Could be the pcv
ok numpty moment now...... :ashamed:
what is the pcv and what does it do...and what are symptoms of it failing please?
 :sad1:
matsu
Offline matsu
  • -Given: 78
Re: car is "missing" -HELP STILLURGENTLY NEEDED
« Reply #23 on: July 18, 2011, 04:20:55 pm »
help still needed
the car is now stutterig/missing at all speeds and even when i drop a gear in paddle shift to accelerate.
still no fault codes shown
i havent fitted the heat sheild yet as havent driven car much at all-will do that tomo
i,m looking for ideas./poss solutions to actually take to a mechanic as i cant get to the place that mapped it.
its doing me head in!
someone mentioned a pcv- what is that and what are symptoms of it failing?
any ideas please-i,m phoning amd tomo to see if they can look at hey can look at it.
thanks in advance
matsu
Offline Richn83
  • -Given: 49
  • -Receive: 85
« Reply #24 on: July 18, 2011, 04:47:03 pm »
Matsu,
PCV allows the crankcase to vent (Positive Crankcase Vent) worth reading
http://forums.fourtitude.com/showthread.php?3590165-eurojet-pcv-fix
http://en.wikipedia.org/wiki/Crankcase_ventilation_system
if the PCV fails then you will experience an eratic idle as the crank case wont be in vacum if PCV is the issue then there are a few fixes from OEM replacement to PCV fixes that remove the issue I think Danish recently fitted one to his car, as you have your engine cover removed it will be easy to see the PCV as it has a nice round part at the front center of your engine.
Offline 56OctyVRS
  • -Receive: 72
« Reply #25 on: July 18, 2011, 04:57:55 pm »
If its missing at all speeds I would suggest new plugs.  The misfire my car had earlier in the topic was cured by fitting new plugs even though the plugs that were knackered were only 2 months old  :surprised:  If it is still doing it then check your coil packs but they normally would bring up a fault code.
« Last Edit: July 18, 2011, 05:00:01 pm by 56OctyVRS »
Offline matsu
  • -Given: 78
« Reply #26 on: July 18, 2011, 05:49:34 pm »
ok thanks guys
i need to book it in and get it looked at.
i did the pcv test thing- i undid the dipstick on idle and the car changed
i undid the oil cap and the car ran like sh*t-but cant rememeber which way round this means!
matsu
Offline matsu
  • -Given: 78
« Reply #27 on: July 21, 2011, 06:00:46 pm »
fingers crossed....service done today-just picked her up and no stuttering at all.
my local guy said the plugs were serious manky so i hope that was the origianl issue!
got me toes crossed also... :drinking: thanks to everyone for their input.
matsu
« Reply #28 on: July 21, 2011, 06:28:43 pm »
Any pics?  :party:
Get chance ti snap some pics? Which intake is it you have?
Offline 56OctyVRS
  • -Receive: 72
« Reply #29 on: July 21, 2011, 07:07:44 pm »
I have the OE engine cover fitted.  I was going to take some pics but I have broken my foot and am just about able to walk on it.  I am going to see if I can get out tomorrow and take some pics as something to do :smiley:
