Author Topic: car is "missing" -HELP STILLURGENTLY NEEDED  (Read 5969 times)
Offline matsu
  • -Given: 78
Re: car is "missing" a beat or two-UPDATE 13/7/11
« Reply #30 on: July 21, 2011, 09:52:23 pm »
I'm running a p flow, as long as you fit the heat shield provided with the kit you should be ok :happy2:
you got any pics of heat sheild in place mate??
matsu
Offline martziniuk
Re: car is "missing" -HELP STILLURGENTLY NEEDED
« Reply #31 on: July 21, 2011, 10:56:00 pm »
Matsu if it were me I would get AFR checked, It could well be running too lean. I seriously doubt the heat issue but a lean AFR would not help this either. Stage 2 seems to be on the limit of the standard fuel pump anyway.
« Last Edit: July 21, 2011, 11:00:58 pm by martziniuk »
