Author Topic: RNS lost position accuracy?  (Read 1649 times)
Offline Lyons
  • -Given: 18
« on: June 30, 2011, 07:52:07 pm »
My RNS has randomly lost position, it now shows my car to be about a mile off.
I haven't had the unit out in a few weeks and ive used it a couple of times since.
I tried resetting but made no difference.
Any ideas?
Re: RNS lost position accuracy?
« Reply #1 on: June 30, 2011, 09:08:28 pm »
Leave it out. The GPS needs 5 or 6 satellites to figure out where you are. You can see this on the GPS viewer.
Offline Lyons
  • -Given: 18
« Reply #2 on: June 30, 2011, 09:32:25 pm »
Leave what out?
How do you get the satellite views up?
« Reply #3 on: June 30, 2011, 10:00:14 pm »
When viewing the map, press the Map button. You should get a window in the top left corner. Tap the title and you get a drop down of options like Overview, Route, etc. GPS Viewer is the one you want. It will display the number of satellites that the RNS510 can see.
And I mean leave the car out in the open with the RNS on. In fact, go for a drive if you want. Once it's found 5+ satellites, it'll get a proper lock. It occasionally happens to me but not so frequently as it once did.
