Author Topic: Make a K03 Neuspeed turbo discharge adapter fit a K04  (Read 3982 times)
Offline kiddfrost
« on: July 02, 2011, 09:44:17 pm »
I had the K03 Neuspeed turbo discharge adapter on my k03 gti and thought is was a worthwhile upgrade. I now have an ed30 and wanted to buy the k04 version of the Neuspeed turbo discharge adapter, but at £270 I thought it was a bit steep considering I already had one for a k03.
I thought right, let’s see what the difference is so I whipped of the adapter and at first glance I thought no chance of that fitting.
After measuring up I realised it would fit with a bit of simple machining. I gave my dimensions and the adapter to an engineering company, got it back and installed it... It fits!
Original
The turbo side is machined back to 35mm then the hole on the turbo side is bored out to 44mm
Modded
Fitted
« Last Edit: December 29, 2011, 10:09:43 pm by kiddfrost »
Re: Make a K03 Neuspeed turbo discharge adapter fit a K04
« Reply #1 on: July 03, 2011, 11:24:29 pm »
Anyone know what spinko means?
They probably supplied that aluminium part.
http://www.spinko.com.pl/index_uk.html
It's not entirely clear to me what alterations were made to your adapter to allow you to fit it on a k04.
« Last Edit: July 03, 2011, 11:44:19 pm by bacillus »
Offline kiddfrost
« Reply #2 on: July 04, 2011, 09:29:22 pm »
Yup, I reckon that's it.  :happy2:
Forgot to put that bit in...  the turbo side is machined back to 35mm then the hole on the turbo side is bored out from 38mm to 44mm (see top photo)
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #3 on: July 10, 2011, 10:41:42 am »
Neuspeed may have traded them straight across for you. They traded my throttle inlet tube from the sound pipe delete version to the sound pipe retained version for me when I put my K04 in and needed the latter version for the dv relocate. They were very kind in that respect. Although shipping may be more $ than the work you had done for yours.
« Reply #4 on: October 02, 2011, 06:43:22 am »
Pics aren't working :(
Can I ask what te cost of the engineering / modification was?  Thanks
« Reply #5 on: October 24, 2011, 12:32:52 am »
that's good to know  :notworthy: although yes shipping & import tax would kill it
« Last Edit: October 24, 2011, 12:48:49 am by Tfsi_Mike »
Offline cheungy
  • "GO APR!"
    • SeatCupra.net
« Reply #6 on: December 29, 2011, 04:48:49 pm »
Interested to do this However the photos are down, Are you able to upload the photos again mate?
I tried to contact Neuspeed however had a reply back from awesome, basically buy new ones...
I want to salvage my own neuspeed ko3 discharge pipe so it works for the ko4
please advise - message also pm'd
Cheers.
MK2 PRE-FL SEAT LEON TFSI SPORT - APR K04
« Reply #7 on: December 29, 2011, 05:12:41 pm »
If you scan my turbo discharge pipe for sale ad you will see what needs doing.
http://www.mk5golfgti.co.uk/forum/index.php/topic,35107.0.html
Offline kiddfrost
« Reply #8 on: December 29, 2011, 10:14:18 pm »
Some pics back up.
Cost about £30 to get modified, very easy for any decent engineering firm to do.
Offline cheungy
  • "GO APR!"
    • SeatCupra.net
« Reply #9 on: December 30, 2011, 07:52:43 am »
