Poll
Wich one would you choose considering the following parameters ?
225/40/18
6 (42.9%)
235/40/18
7 (50%)
245/40/18
1 (7.1%)
245/35/18
0 (0%)
Total Members Voted: 14
Author Topic: Rim/tire size choice for track  (Read 16129 times)
Offline Chalkie
Re: Rim/tire size choice for track
« Reply #15 on: August 17, 2011, 10:18:20 pm »
Chalkie, what suspension have you got ? Any pics with the fenders/wheels ?
AST RACE DAMPERS
KW CAMBER ADJUSTABLE TOP MOUNTS
Offline fuscobal
  • -Receive: 27
« Reply #16 on: August 20, 2011, 10:59:27 am »
Made some comparison calculations between the 2 wheels I have for track :
1) OEM Denvers 7.5x17'' ; ET51 ; Kumho V70a on 225/45/17 (224 effective width)
2) TD 1.2 PRO Race 8x18'' ; ET45 ; Toyo R888 on 235/40/18 (244 effective width)
OEM > 7.5'' = 191mm
Tire = 224mm
Tire goes out of the rim on each side (224-191)/2 = 16.5mm
ET51 means :
1) the distance from the rim mounting point to the outer tire extremity would be 224/2 - 51 = 61mm
2) the distance from the rim mounting point to the inner tire extremity would be 224/2 + 51 = 163mm
Aftermarket > 8'' = 203mm
Tire = 244mm
Tire goes out of the rim on each side (244-203)/2 = 20.5mm
ET45 means :
1) the distance from the rim mounting point to the outer tire extremity would be 244/2 - 45 = 77mm
2) the distance from the rim mounting point to the inner tire extremity would be 244/2 + 45 = 167mm
By comparison :
1) The aftermarket tire will stick out 77-61 = 16mm more than OEM (this is bad for those that have clearance issues)
2) The aftermarket tire will be closer to the strut by 167-163 = 4mm (this is also bad for those who have strut clearance issues)
Mk5 GTI 6MT - Revo stage 3
Offline rex
  • -Given: 50
  • -Receive: 74
« Reply #17 on: August 20, 2011, 01:44:32 pm »
Looks like you might need some Kerscher or Seibon fenders!
Offline fuscobal
  • -Receive: 27
« Reply #18 on: August 20, 2011, 06:21:41 pm »
Only way to know it is when I'll install the new wheels at the end of september...hopefully not !
Offline Chalkie
« Reply #19 on: August 20, 2011, 10:59:25 pm »
here is the car running load on 255 35 18 toyo 888's she's currently on 255 35 18 Yokos AD08's both give no problems with rubbing either loaded or on full lock...
Offline fuscobal
  • -Receive: 27
« Reply #20 on: August 21, 2011, 08:06:09 am »
Can't understand how is that possible with OEM fenders. What do you mean by rolled slightly ? (5mm, 1cm ?). Chalkie, please also specify what ET have you got to those 8.5 x 18 rims ?
PS : Maybe those AST's are much stiffer than our B16s !
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
« Reply #21 on: August 21, 2011, 08:26:09 am »
Linear springs maybe?  :smiley:
Over the top mod list ;o)
Offline Chalkie
« Reply #22 on: August 21, 2011, 09:21:54 am »
et50 8.5x18
they use a special machine to roll the arches ask your local bodyshop...
Offline rex
  • -Given: 50
  • -Receive: 74
« Reply #23 on: August 21, 2011, 09:28:02 am »
And guys, I also think the circuit is important.
I have no rubbing at Hungaroring with a 2cm lower suspension and ET40 rims. But I have rubbing at Nordschleife with 2cm higher suspension and ET50 rims.
So my guess is that there is rubbing on that Golf on Nordschleife. It just depends where you are going.
I will search for a setup that is ok for all tracks because rubbing is annoying and also dangerous.
Offline Chalkie
« Reply #24 on: August 21, 2011, 09:56:54 am »
no rubbing at Nordschliefe either
Offline rex
  • -Given: 50
  • -Receive: 74
« Reply #25 on: August 21, 2011, 10:02:41 am »
Well guys, it just makes no sense to me...
We have the TT arms that take the wheel out by another 1cm, but still it makes no sense.
*Edit laurent had something similar to the TT arms, 8x18 ET 45 OZ wheels and had rubbing on the Nordschleife. I just don't understand why we have so different results...
« Last Edit: August 21, 2011, 10:32:31 am by rex »
Offline fuscobal
  • -Receive: 27
« Reply #26 on: August 21, 2011, 01:28:24 pm »
rex, It's also weird the 255 tire doesn't touch the damper on the inside. For me, with 235 the tire sits about 10mm away from the Bilstein damper and I have ET46. 255 should touch it with ET50 !!!
Offline rex
  • -Given: 50
  • -Receive: 74
« Reply #27 on: August 21, 2011, 01:56:27 pm »
 :grin:. Nice... So, this is clearly out of my league. O have no idea what to believe!
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #28 on: August 21, 2011, 02:54:50 pm »
+1
many of the boys in the US run 245 or even 255
Are the US model fenders so different or don't they care about rubbing?  :confused:
"You get what you pay for."
Offline Chalkie
« Reply #29 on: August 21, 2011, 11:51:14 pm »
oh yeah i have the tt arms too...
