Author Topic: Buying second hand rns510  (Read 1348 times)
Offline deebow
« on: July 04, 2011, 01:56:50 pm »
Hi
iv been offered a secondhand rns510 version b at £350 and was wondering when i pick it apart from testing it to make sure it reads cd and nav works is there anything else i should be looking for
thanks
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: Buying second hand rns510
« Reply #1 on: July 04, 2011, 01:58:11 pm »
Just the general condition I guess.  If it works when you fit it then that's about all you can do.
Stu...
Offline deebow
« Reply #2 on: July 04, 2011, 03:39:48 pm »
From reading around ive read that units that are stolen they do something to the eprom so when u try and update it bricks it.  Is there any way to spot t this. And does it work on all version.  Also o whats the latest vsrsion for the version  b stereo
Offline deebow
« Reply #3 on: July 04, 2011, 09:52:28 pm »
just been speaking to the seller and hes advised it doesnt need a code when you fit it into the car. could this mean its one thats had the eprom soldered
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #4 on: July 04, 2011, 10:07:16 pm »
It will need a code, it might not have needed a code if fitted, removed and refitted to the same car.
Or is one of you getting confused with coding as in VCDS?
If he's telling you it doesn't have the 4 digit code that might account for the lower price.  Some of us have a tool which can write a new pin code to the unit.
Stu...
« Reply #5 on: July 04, 2011, 10:24:40 pm »
I guess I would check to see if the seals had been broken.
Offline deebow
« Reply #6 on: July 04, 2011, 10:49:17 pm »
hes saying that you just fit it and itd work without a code. even offered to fit it.
can i ask howmuch do people who have the tools to change the pin charge for it
thanks
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #7 on: July 05, 2011, 08:37:32 am »
I would get the pin for you for £25 but I'd need to see the unit.
Stu...
