Author Topic: Audi Bluetooth options?  (Read 1560 times)
Offline scotta
  • Edition 30
« on: July 04, 2011, 01:57:54 pm »
Need some advise on the bluetooth options for the A3.
I had the Parrot mki9200 in the golf which i just left in place because i never thought it was much use.
So question being what are my options for the A3 do i go OEM or is there any aftermarket units that are better. Additionally any ideas the costings for each options?
Ive tried searching a few audi forums but people dont seem t write anything much sensible or constructive on most audi forums!
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: Audi Bluetooth options?
« Reply #1 on: July 04, 2011, 02:34:56 pm »
OEM is much the same as the Golf/Octavia setup.  The correct location for the unit is under the passenger seat.
Stu...
Offline scotta
  • Edition 30
« Reply #2 on: July 04, 2011, 10:31:26 pm »
You wouldnt happen to have a retrofit guide handy and know the part numbers required?
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #3 on: July 04, 2011, 10:36:22 pm »
Something like 8P1 862 335 will do you.
The install is a bit like the Golf etc.  When you pull out the passenger seat and lift the carpet you'll find a polystyrene moulding, pull that out and make a few small adjustments and you'll find the interface fits perfectly.
Stu...
Offline scotta
  • Edition 30
« Reply #4 on: July 04, 2011, 11:24:34 pm »
Where do you connect the unit to - is there wiring in place under the seat or do you need to run the wiring to the back of the headunit?
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #5 on: July 05, 2011, 08:43:28 am »
No, you'll never find 'free' wiring in place on a VAG car  :evilgrin:
Connect to the back of the RNS-E or Concert Radio etc.
Stu...
