Author Topic: ED PESCARA WHEEL PAINT  (Read 3400 times)
Offline cossy
  • -Given: 17
  • 57 REG ED30 5325 MILES!
« on: March 19, 2009, 06:51:28 pm »
Hi guys,
After many emails etc I have a colour for the Pescara.
Try
http://www.wheelpaints.co.uk/category_Car_Manufacturers_Colours_Volkswagen_1.htm
Cheeky sod used my picture's sent him!
Ordered a can tonight will let you all know how it goes. :smiley:
Offline 182_blue
  • -Receive: 54
Re: ED PESCARA WHEEL PAINT
« Reply #1 on: March 19, 2009, 06:54:12 pm »
wonder where they got the colour from ?, i hope it matches
Offline cossy
  • -Given: 17
« Reply #2 on: March 19, 2009, 06:58:32 pm »
So do I!
this was the email received:-
Gavin
Thanks for the picture, we have this colour in our libary, we have many requests for edition 30 colour, however people normally asume it is the metallic grey.
That is why we check the pictures.
We can do this in aerosol, I will put it on the website under VW manufactures colours.
regards
Terry
Im also in correspondence with BBS, they just need the codes on the inside of the wheel, does anyone have this?
Save me taking the wheel off at the weekend!
CHeers
Offline 182_blue
  • -Receive: 54
« Reply #3 on: March 19, 2009, 07:01:40 pm »
So do I!
Gavin
regards
Terry
CHeers
i didnt think BBS told people the colour ?, they direct you to VW
Offline cossy
  • -Given: 17
« Reply #4 on: March 19, 2009, 07:05:58 pm »
So do I!
Gavin
regards
Terry
CHeers
They haven't yet, email was as follows:-
thank you for your enquiry.
Sorry, but I don´t know what wheel type you have. And so, I can not check how I can help you.
On the wheel inside there must be the wheel type, offset, and others. Please give me these numbers, then so I will help you.
The wheel type consists of two letters plus three numbers, I.e. CH009.
Mit freundlichen Grüßen/Kind regards
Miriam Gerger
Teamassistentin Projektmanagement
BBS International GmbH
Welschdorf 220
D – 77761 Schiltach
[/i]
Straight from the father land!!! :smiley:
Offline 182_blue
  • -Receive: 54
« Reply #5 on: March 19, 2009, 07:07:44 pm »
YEH, i think when you give them the code they will refer you too VW lol, i had the codes somewhere
So do I!
Gavin
regards
Terry
CHeers
Miriam Gerger
Welschdorf 220
D – 77761 Schiltach
[/i]
Phil Mcavity
« Reply #6 on: March 19, 2009, 08:02:59 pm »
i will order some of this once i get confo wether its a good match.  :happy2:
Keep us informed how yours looks cossy  :drinking:
Offline cossy
  • -Given: 17
« Reply #7 on: April 05, 2009, 06:36:13 pm »
Ok, after two weeks of prep work & using the new paint i can confirm it is a close match but..... not perfect.
Coming out slightly lighter.
I had a scrape on the outer edge, so filled, primed & painted just this.
You wouldnt really know its been done. ( and Im a fussy **stard!)
So I  would say i am 90% happy with it, definately doesnt stick out anymore.
Used Wurth Laquer which is what most German wheel manufaturers use.
The worst thing was blending it in but the old cotton buds dipped in thinners did the trick!
With post pictures soon. :happy2:
Offline 182_blue
  • -Receive: 54
« Reply #8 on: April 05, 2009, 07:10:13 pm »
would another coat of the paint darken it ?
Offline pitch3110
« Reply #9 on: April 05, 2009, 07:34:19 pm »
Sounds good to me Cossy & great work
HIS (collected 12.10.09) - B8 A4 2.0TDI-143PS Multi Exec S-Line Saloon...Lovin' Lava, 19's, MMI & lots more
TOY - 2001 Westfield 2.1 SEW,172bhp gocart.
HERS - Edition 30 Golf GTI no:0602, 3dr, Steel Grey, Xenons, Comfort Pack & lots more...
Offline cossy
  • -Given: 17
« Reply #10 on: April 06, 2009, 09:37:41 am »
Yes it probably would, was getting a bit impatient as car off the road for two weeks!
One good thing would be to make a template to fit just inside the wheel rim so the outer rim just exposed.
Would save a great deal of time masking off etc.
Any ideas? suppose could do the blue peter bit with a pencil & string put it needs to be cut out accurately.
« Last Edit: April 06, 2009, 09:40:40 am by cossy »
Offline 182_blue
  • -Receive: 54
« Reply #11 on: April 06, 2009, 12:33:11 pm »
is the paint opaque ?, i thought it was supposed to be, if so another coat will make it darker
Offline pitch3110
« Reply #12 on: April 17, 2009, 10:39:32 am »
Cossy,
Started last night using putty as a filler, which was a nightmare.
Going to get some metalik & give it a try over the weekend.
What did you use & did you mask the whole wheel off leaving just the outer free.
Thinners?????? anything special.
ta matey
Offline cossy
  • -Given: 17
« Reply #13 on: April 17, 2009, 02:30:17 pm »
Hi Mate,
I did the following:-
Let the tyre down, cut out strips of newspaper, pushed down on side wall of tyre with a piece of wood (hammer handle is good!)
Pushed in the paper all the way round the tyre then tape them down.  Saves any paint on tyre, re-balancing, tyres off & on etc Sounds weird but it does work!
Then used low tack masking tape (3m Blue) around the rim, about half way down the outer rim where it comes down to the wheel.  Use small strips as it needs to be angled to the rim(hope this makes sense).
The rest of the wheel just use newspaper & masking tape.
I used special filler they use for model aircraft, its a sort of white compound easy to work with sets in 10 mins (will find out exactly the name of it)
Rub down the fill areas & lightly the rest of the top of the outer rim.
Clean with thinners
Then used a Filler primer.
Remove the blue masking tape & gently rub down any lip or you can use a cotton bud with thinners.
Re apply masking tape just below where the primer finishes.
Apply top coat, remove masking tape again and repeat the rub down of any paint lip.
I would say about four coats of paint to get the colour dark enough, do this over two days though. (2 & 2 coats)
The clear coat can be sprayed directly without any masking, just spray around the outer edge. (used Wurth clearcoat)
Gently polish with a cut compound, leave for another month or so and polish again using more pressure if required.
Its not a quick job by any means, but alot better than a touch up stick method! :happy2:
« Last Edit: April 17, 2009, 02:38:21 pm by cossy »
Offline pitch3110
« Reply #14 on: April 18, 2009, 12:23:12 am »
cheers bud for that & some good pointers. :happy2:
may start at the weekend :scared:
