Author Topic: Is it ok to have stiff rear ARB on stock suspension?  (Read 888 times)
Offline berg
  • -Given: 49
  • -Receive: 38
« on: July 04, 2011, 10:51:41 pm »
Hi guys,
Am running oem suspension but with WALK, TT wishbones and Eibach arbs front and rear.
Have recently set the rear to stiff after discussing with Janner Sy and left the front on soft.
Have been advised that it is not wise to run a stiffer bar unless have lowered with uprated dampers/springs but not sure whether this makes sense or not as have discussed with Sy and he reckons would make it more forgiving.
Any suspension gurus with any comments would be welcomed?
Ta
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=ngq36q08dkuks5emh8374f8sbk&/topic,19740.0.html
Re: Is it ok to have stiff rear ARB on stock suspension?
« Reply #1 on: July 04, 2011, 10:59:45 pm »
Im running an autotech rear ARB  on the middle setting on stock suspension and its fine.
Thats just my opinion.  :happy2:
Offline berg
  • -Given: 49
  • -Receive: 38
« Reply #2 on: July 04, 2011, 11:21:07 pm »
Yeah but yours has three settings whereas the eibach only has two. I think will test it a bit more before deciding what to do.
incidentally rich why are you running stock suspension? Is it because you want your car to LOOK oem even if it is not in actual fact?
« Reply #3 on: July 04, 2011, 11:22:56 pm »
2 Reasons. Cost and practicality (i dont want to end up with a hard ride because its my daily)
Offline berg
  • -Given: 49
  • -Receive: 38
« Reply #4 on: July 04, 2011, 11:33:15 pm »
yup same here + grounding my front splitter all time as it is
