Author Topic: Setting drls in xenons as indicators?  (Read 915 times)
Offline geordie56
« on: July 06, 2011, 08:45:21 pm »
Hi, on my rocco I have xenons and want to set the drl within the cluster as the indicator, I have bought some orange bulbs for this and have been told it can be done. Does anyone know the best way of achieving this without cutting the loom? Has anyone carried this out on there golf? It's a 59 plate in case you need to know the my.
Offline mortygttdi
  • -Receive: 146
Re: Setting drls in xenons as indicators?
« Reply #1 on: July 07, 2011, 05:58:08 am »
I think there is coding in the central electrics/bcm to use the sidelights/drls has indicators but only for backup purposes i.e if the indicator bulb/s should go then it switches to the sidelight/s I don't think its set like that has default so will need VCDS to look for it.
Darren
Offline geordie56
« Reply #2 on: July 07, 2011, 05:08:08 pm »
So would this be able to be set up as a permanent solution without cutting the loom do you think? Thanks for the help btw. Not local to Manchester and wanna have a go are you?
Offline mortygttdi
  • -Receive: 146
« Reply #3 on: July 08, 2011, 06:17:07 am »
I did find it in the CECM and its Byte 14 bit 0 but its defo a backup function so not permanent
I'm in Leeds mate your quite welcome to stop by any time if your in the area :happy2:
Darren
