Author Topic: ITG and Twintake (Noisy/Quiet) ?  (Read 6331 times)
Offline robin_nerf
« on: July 08, 2011, 10:18:59 am »
Hello everyone.
I'v read many post from this forum by searching on google so i try to make a question here even if i'm not a Golf owner.
I have a new (2011) Seat Leon Cupra R 2.0T and are looking for a new CAI.
I'm intressted in Forge Twintake or Maxogen ITG, but i cant decide which.
Is ITG to noisy or is Twintake to quiet ?
(I'm going to install a new Forge DV and a blow off at the same time as installing the new CAI).
Best regards / Robin from Sweden.
Re: ITG and Twintake (Noisy/Quiet) ?
« Reply #1 on: July 08, 2011, 03:33:15 pm »
Both intakes can be noisey depending on how you operate the acclerator pedal.  :evilgrin:
Overall the itg is louder than the twintake.
Offline Fizgti
« Reply #2 on: July 08, 2011, 10:19:56 pm »
I like the itg it gives you better power n noise
Offline chungster
« Reply #3 on: July 08, 2011, 10:32:59 pm »
Having heard SteveP's ITG at Bedford...I would say they're both the same on noise level.
Unless you get their latest closed filter system (being tested on a couple of cars at the mo I think)...it's quieter I'm led to believe!
Offline robin_nerf
« Reply #4 on: July 09, 2011, 09:36:20 pm »
I order a Forge Twintake, Blow Off Adaption Spacer and Vacuum Operated Valve yesterday, i hope that i will me satisfied with this :)
Since i have 320hp now and are planned to have about 350+ i order the Forge Valve since i have read that it is stronger then the stock and i like that blow off noise so order aswell a spacer for that ;)
Offline baldwined30
« Reply #5 on: July 10, 2011, 12:35:18 pm »
Just fitted a twintake. Its not too bad but then i dont want a screamer of a car! you can hear it sucking more with the windows closed! as for power, not sure but it seems to pull harder with it on further up the rev range, im guessing thats because theres better air flow! Not sure on ITG, never heard one apart from vids. they are both a good product but personal preference! i know all these intakes sound better on manual!  :sad1:
Ed30
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
« Reply #6 on: July 10, 2011, 01:57:00 pm »
Save your money on the Forge blow off spacer, you get the sound when you fit the Twintake anyway, also just buy the standard revision D diverter valve instead of the forge one as it does the same and don't require maintainance, so in all buy the Twintake and a standard diverter valve revision D
Over the top mod list ;o)
Offline baldwined30
« Reply #7 on: July 10, 2011, 02:01:35 pm »
Just checked my oem version C! Still in one piece! Guess the superchips map isn't good enough to blow it haha
Ed30
Offline robin_nerf
« Reply #8 on: July 10, 2011, 04:46:06 pm »
What kind of maintenance does the Forge DV need ?
Forge, as i know them, make really good products for tuning car's or tuned car's.
Is the Standard Rev DV expensive or cheaper then the Forge ?
Offline baldwined30
« Reply #9 on: July 10, 2011, 05:07:28 pm »
cheaper, OEM is about £45 and the forge is about£110
Ed30
Offline robin_nerf
« Reply #10 on: July 10, 2011, 05:47:44 pm »
The standard revision D diverter valve you are talking about, is it this one : http://www.awesome-gti.co.uk/product.php?xProd=13242&xSec=360
EDIT : I guess there is no difference between the OEM DV D and Forge DV in sound ?
« Last Edit: July 10, 2011, 06:04:56 pm by robin_nerf »
  • -Given: 243
  • -Receive: 154
« Reply #11 on: July 10, 2011, 06:48:10 pm »
The sound is the same, and yes the awesome one is the rev. D DV. Forge DV needs to be dismantled and lubed app. every 6 month.
The sound you are after comes when you removed the original airbox and fit the Twintake, along with the pift from the DV and wastegate chatter you get a breathing sound from the intake in the fender  :happy2:
Offline baldwined30
« Reply #12 on: July 10, 2011, 06:50:44 pm »
some people say that the version D ends up being better that the forge one. Im not sure either way! Always find these forge ones end up sounding like a punto turbo! Just my opinion  :happy2:
Ed30
Offline robin_nerf
« Reply #13 on: July 10, 2011, 07:20:11 pm »
Really big thanks guys for saving me some money :D
But i'm a bit concerned if i get that Blow Off sound without the spacer ?
The sound that i want is this :
(1,40 in the clip)
Offline baldwined30
« Reply #14 on: July 10, 2011, 07:28:39 pm »
you really want it that loud??
Ed30
