Author Topic: rns 510 no signal  (Read 10785 times)
Offline v2brett
Re: rns 510 no signal
« Reply #15 on: July 16, 2011, 10:26:29 pm »
well this is still happening to my mates, it lost all sats again today.  anyone got any suggestions of the best place to locate the antenna in a mk6 golf?
Still Here!
Offline JoeGTD11
« Reply #16 on: July 17, 2011, 06:38:27 pm »
I have mine up in behind the 2 central vents and it seems to work well. I wrapped the antenna up with felt tape to make it thick enough and wedged it up in there.
I can typically see 11-12 satellites and usually track 6-8 of those.
Offline v2brett
« Reply #17 on: July 18, 2011, 10:20:04 pm »
damn thats where it is and it used to work perfect, he might have to try a new antenna.
Still Here!
Offline VeeDub
« Reply #18 on: July 19, 2011, 02:53:55 pm »
Sounds like it must be the antenna, because as per my post above I have just moved mine to this location and the problem is solved.
Offline LouCyffer
  • -Given: 36
  • -Receive: 63
« Reply #19 on: July 19, 2011, 03:08:53 pm »
If possible, get the antenna out so you can move it while the unit is on, then use the GPS status screen to monitor what happens when you move it around.
Have you tried this?
Offline v2brett
« Reply #20 on: July 19, 2011, 10:11:17 pm »
yeah mate tried that and the most it picked up with the antenna outside stuck to the roof was 4/5
Still Here!
Offline v2brett
« Reply #21 on: August 05, 2011, 11:20:01 pm »
just to let anyone know this prob was fixed with a new antenna  :happy2:
Still Here!
Offline LouCyffer
  • -Given: 36
  • -Receive: 63
« Reply #22 on: August 06, 2011, 07:42:15 am »
Nice one, glad to hear you got it solved  :happy2:
