Author Topic: RNS510  (Read 6734 times)
Offline MaverickFSI
  • Tornado Red Ed30 DSG
RNS510
« on: July 10, 2011, 02:43:01 pm »
What is the difference between the version B & C of this head unit? I've currently got the version C in the Scirocco and have never used the unit in the Mk5 Golf. There seems to a difference in price, is that because version C is LED?
Found some on eBay;
http://cgi.ebay.co.uk/VW-VOLKSWAGEN-RNS-510-SAT-NAV-RNS510-Version-C-LED-/200627193732?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2eb6500784 - Version C
http://cgi.ebay.co.uk/VW-SAT-NAV-DVD-RNS-510-MFD3-B-VERSION-/220810122178?pt=UK_Audio_TV_Electronics_In_Car_Entertainment_GPS_In_Car_Audio_Players_PP&hash=item33694f13c2 - Version B
Cheers.
Great balls of fire!
Retro Dubs on the go;
'91 Corrado 20vT - Project still going... and going...
Offline sam
  • 127.0.0.1
    • Calibre Connections LLP
Re: RNS510
« Reply #1 on: July 10, 2011, 02:48:38 pm »
Yes correct!!!! :happy2:
Offline MaverickFSI
Re: RNS510
« Reply #2 on: July 10, 2011, 03:50:13 pm »
Thanks for the confirmation bud  :wink:
Offline Leonard
Re: RNS510
« Reply #3 on: July 10, 2011, 04:39:31 pm »
For info if your MK5 is pre March 2007 you may get battery drain problems with the version C...
Matt
Offline MaverickFSI
Re: RNS510
« Reply #4 on: July 10, 2011, 04:52:38 pm »
Matt
Hi Matt, yes I have just read that in a monster thread regarding the definitions of the A, B & C variants of the RNS510.
At this stage I couldn't tell you the exact month of production as I haven't picked my Ed30 up from VW yet, this Thursday  :party: :jumpmove: :pomppomp: :happy2:. It's a 57 plate.
Are there any people on here who can fit them? Once I purchase one, I'd be very interested to watch and be the on site tea boy  :signLOL: I've never pulled one out nor have the correct tools to do so, so for the first time I'd rather seek the guidance of someone who knows what they are doing.
I've currently got a Scirocco TDI 140PS and that has, it seems, the C version, which I think is wicked. However, am I right in saying that you can get a LCD & LED C version?
« Last Edit: July 10, 2011, 04:54:10 pm by MaverickFSI »
Offline LouCyffer
  • -Given: 36
  • -Receive: 63
Re: RNS510
« Reply #5 on: July 10, 2011, 04:56:28 pm »
SteveP, MortyGTTDi, vRSCarl.......
Actually, the physical fitting can be done by most folk with a bit of patience. It's straightforward.
Have a look at
http://www.r32oc.com/tutorials-guides/18955-rns-510-mfd-install-how-guide-inc-pin-swap.html
http://www.my-gti.com/2564/upgrading-2nd-generation-headunits-rcd-300-rcd-500-mfd2-to-3rd-generation-headunits-rcd-210-rcd-310-rns-310-rns-510-rcd-510
http://www.my-gti.com/2484/installing-gps-antenna-inside-dash-in-the-volkswagen-golf-and-jetta
to start you off.
You may need an aerial adaptor if you're starting with a second gen head unit. See:
http://www.my-gti.com/1088/upgrading-2nd-generation-radios-rcd-300-rcd-500-to-3rd-generation-rcd-210-rcd-310-rns-310-rns-510-rcd-510-antenna-adapter
The Partnumber is 7L6 051 551 and having asked my local dealer, they catagorically stated no such part existed. Having found the above link I went back and made the parts flunky look stupid (not difficult). :evilgrin:
« Last Edit: July 10, 2011, 05:06:01 pm by LouCyffer »
Offline Leonard
Re: RNS510
« Reply #6 on: July 10, 2011, 05:31:34 pm »
It is really easy to fit, dont be afraid to do it yourself. Probably take 30 mins and Im pretty sure you will need the aerial adaptor.
I just stuck the gps antenna underneath the top climate cover on the dash (plenty of room on left or right hand side) and reception is fine.
Matt
Offline MaverickFSI
Re: RNS510
« Reply #7 on: July 10, 2011, 06:04:00 pm »
Have a look at
to start you off.
Great links mate, nice one  :happy2:
Offline MaverickFSI
Re: RNS510
« Reply #8 on: July 10, 2011, 06:06:03 pm »
Matt
Cheers Matt, I'll bear that in mind  :happy2:
Offline LouCyffer
  • -Given: 36
  • -Receive: 63
Re: RNS510
« Reply #9 on: July 10, 2011, 06:20:54 pm »
Your welcome, Mav. Mine was self-fitted, no VCDS coding necessary. And by the way, the aerial adaptor is about £28 for two bits of wire :confused:
Offline MaverickFSI
Re: RNS510
« Reply #10 on: July 10, 2011, 06:34:12 pm »
Cool. So if I buy one off eBay brand new, for example, will it need coding or will it just literally plug 'n' play? Yeah, when I read the installation thread you posted and saw the cost of the two lengths of cable I thought it was abit expensive like, how much is VW tax these days, damn!
  • -Receive: 291
Re: RNS510
« Reply #11 on: July 10, 2011, 07:05:50 pm »
VCDS means you can tell the car it's there, so it comes up on the highline dash and you can use the mfsw. If you don't have those, you can probably get away without the need to code it.
Fitting is easy but trying to do it withouth breaking any dash clips is a bit more challenging. :innocent:
Offline MaverickFSI
Re: RNS510
« Reply #12 on: July 10, 2011, 10:34:54 pm »
Based on that Stealth it will need coding then, as I have the MFSW set up. How do I go about that then? Dealers or does someone possess the software to code the headunit to the car?
Gracias.
  • -Receive: 291
Re: RNS510
« Reply #13 on: July 10, 2011, 11:13:56 pm »
Have a look in the VCDS Register thread. Hopefully there's someone close enough to help out.
Offline LouCyffer
  • -Given: 36
  • -Receive: 63
Re: RNS510
« Reply #14 on: July 11, 2011, 08:17:51 am »
I think Eddie-NL is your man for the Nolfolk area
