Author Topic: Tyre Pressure Monitor Swicth retrofit- Which pin?  (Read 7540 times)
Offline gtlee
« on: July 10, 2011, 08:23:10 pm »
Fitted the TPMS today which wasn't too bad but getting the wire to the ABS through the bulkhead was longer than expected.
All was well for the fitting side of things but hit a slight problem after coding the TPMS,the beep won't come on but the TPMS icon is lit on the cluster.
I'v connected the wire to Pin 41 of the ABS is this correct for my ABS:
Address 03: ABS Brakes (-----)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 AE    HW: 1K0 907 379 AE
   Component: ESP MK60EC1   H35 0104
   Revision: 00H35001
   Coding: 163B600D09240001681206E7901A0082B100
   Shop #: WSC 01316 785 00200
   VCID: 75EAF32B60E4
I've read in another forum it maybe pin 35 can anyone advise.
BTW its a 2008 DSG.
GTlee. :smiley:
« Last Edit: July 10, 2011, 09:20:43 pm by gtlee »
Golf V 5DR DSG GT Sport,,Xenons,Full leather,18'Charlestons,Lux pack,storage pack,folding mirrors,front armrest, retrofited--mk5 gti  grilles,fog lamps grilles,GTi rear bumper,coloured coded sideskirts, VIM RNS-510 C,MK6 MFSW with paddles,GTi DSG gear lever,Cruise control,Highline.Rain sensor with window auto closure,TPMS.7P6 Bluetooth.
Mods to come: RVC, and.................
Offline gtlee
Re: TPMS
« Reply #1 on: July 10, 2011, 08:48:30 pm »
Anybody????? :pomppomp: :pomppomp: :pomppomp:
Offline gtlee
Re: Tyre Pressure Monitor Swicth retrofit- Which pin?
« Reply #2 on: July 10, 2011, 09:32:34 pm »
Helloooooooooooooo???? :signLOL:
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #3 on: July 10, 2011, 09:57:46 pm »
Yep I believe pin 35 is the correct one for DSG cars  :happy2:
Offline StephenED30
  • -Receive: 53
  • Edition 40 No 135
Offline gtlee
« Reply #5 on: July 10, 2011, 10:05:09 pm »
Gonna try pin 35 tomorrow and will report back the results,many thanks for the advise guys. :happy2: :happy2:
Offline gtlee
« Reply #6 on: July 11, 2011, 09:08:26 am »
UPDATE:
Popped out early this couldn't sleep (don't know why,heh?) unplugged ABS wire from Pin 41 which was a pain as it well and truly in the connector and wasn't coming out.
After a few cursing and swearing  (not at you Eddie) and 20mins later the pin removed itself from the connector and with it I made very sure where pin location 35 and in that the grey wire went in.
Checked and put some more air the tyres and resetted the TPMS via VCDS and pressed the TPMS switch and eagerly waited for the "bong" and yes it "bonged" alright.
Well chuffed with another "Mod" under my belt,can't wait to save up for the next! :jumpmove:
Offline gtlee
« Reply #7 on: July 11, 2011, 11:29:16 am »
Another problem the ESP button doesn't light the icon on the cluster as before any ideas?? :sad1:
Offline gtlee
« Reply #8 on: July 11, 2011, 12:39:22 pm »
Bad connection all ok now.
Offline big al
« Reply #9 on: July 11, 2011, 01:21:26 pm »
Does this come with instructions? thinking about fitting one of these myself as get flat tyre paranoia.
Where did you get it?
Do you have a run through if the instructions aren't the best?
Offline gtlee
« Reply #10 on: July 11, 2011, 01:56:05 pm »
It depends where you get it from, Eddie-NL supplied mine and yes it came with instructions and support if you get stuck.
The hardest or should I say the most time consuming is threading through the bulkhead for the ABS wire but other than that its pretty straight forward and also you need coding with VCDS.
As from my post here I had wired to wrong pin loacation at the ABS but thats because I had the newer ABS pump.
I had a good look at this retrofit on here and at other forums to get a better idea whats involved pictures speak louder than words and if you do this retrofit I'll be more than happy to to do a run through.
Gtlee :happy2:
Offline Betty02
    • iBett
« Reply #11 on: July 11, 2011, 02:06:50 pm »
I thought all GTi's came with this?
Mine went off once when I hit a pot hole, I have since had 3 different sets of alloys on, all with diff rent pressures and it has never gone of?
Does it activate on a drop or any psi or when a tyre gets below a certain PSI? I thought changing alloys would've activated it tbh! All various sizes 17's, 18's and 19's!
ADMIN NOTICE: Please do not use the site for advertising!
Offline gtlee
« Reply #12 on: July 11, 2011, 02:18:35 pm »
Mines not a Gti but soot wagon I would of thought all Gti had Tpms as standard.
Not quite sure how the system works but no doubt someone on here can answer that question.
Offline alexperkins
  • -Receive: 99
« Reply #13 on: July 11, 2011, 10:35:17 pm »
It uses the ABS rotor to detect the rolling radius of the wheel. If it increases or decreases significantly, the TPMS warning comes on - simples
Offline DamoP
  • -Receive: 115
  • 2007 Edition 30 number 1242
« Reply #14 on: July 12, 2011, 07:14:56 pm »
kufatec also make the loom , all you need is the switch off of ebay for a tenna
MDI Armrest & Glovebox kits
Armrests, cloth and leather
