Author Topic: OEM Rear Brake Pads - Part Number  (Read 4109 times)
Offline blackmagic
« on: July 11, 2011, 10:40:39 pm »
Just need part numbers for standard GTI rear brake pads. Noticed at weekend when washing that they are LOW! I had a search but can't find a post with info.
Is there a sticky somewhere with service part numbers etc? I think I remember seeing one at some point.
Thanks Jim
Black GTI K03 Revo Stage 2+,
Offline blackmagic
Re: OEM Rear Brake Pads - Part Number
« Reply #1 on: July 12, 2011, 08:50:26 pm »
Anyone! need to get these asap Thanks in advance guys
Offline liver
« Reply #2 on: July 14, 2011, 12:48:47 pm »
i would also like this part number if possible
cheers
Offline DaveB@Vagbremtechnic
  • Trader - 2014
  • -Receive: 130
    • Vagbremtechnic.com
« Reply #3 on: July 14, 2011, 01:48:41 pm »
Offline blackmagic
« Reply #4 on: July 14, 2011, 11:57:29 pm »
Are you sure this is correct part number for standard GTI rear pads, from putting into google etc this number seems to be for MK5 R32 / TT/ S3 vented disc 320mm. Just wanted to double check before I order.
Offline FamilyDub
  • ...who needs a diesel?
« Reply #5 on: July 20, 2011, 02:25:57 pm »
^^ Dave, this forum (below) seems to think the part number 1K0698451E is for 310mm rear brakes, and 1K0698451D is for 286mm.
http://forums.vwvortex.com/showthread.php?2789446
Which is it, or are they interchangeable and it doesn't matter...  :grin:
MKV GTI | Reflex Silver | 5-dr, Family-Spec | 17" w/anthracite Finish | Manual | Highline | Cruise | Revision 'D' DV | Dirty Pipes |
Offline liver
« Reply #6 on: August 09, 2011, 11:26:43 am »
did we ever find out if these were the correct ones for the mk5 golf gti??
