Author Topic: ED30 brake pads  (Read 905 times)
Offline Megy_ED30
ED30 brake pads
« on: July 15, 2011, 09:44:55 am »
Hi All,
Just a quick enquiry, are the ED30 brake pads the same as the GTi brake pads.  I have the clunking noise coming from the front of the car when I apply the brakes and someone has asked if the wrong brake pads could be installed.  The garage I bought the car from did change Discs and Pads before I picked up the car but after I test drove it, so could this be the problem?
Cheers all,
Ian
07 Plate GTi ED30 DSG - Grey - Standard (but not for long)
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=fda2lu2hoc3ahka1v6gk5spg2b&/topic,19740.0.html
Re: ED30 brake pads
« Reply #1 on: July 15, 2011, 09:53:11 am »
Yes... they are the same. The entire braking system is the same on the GTI 200PS or 230PS
Offline Megy_ED30
Re: ED30 brake pads
« Reply #2 on: July 15, 2011, 10:01:25 am »
Doubt it will be that then, back to the drawing board on the noise then.
Re: ED30 brake pads
« Reply #3 on: July 15, 2011, 10:04:05 am »
Does the clunk happen every time you brake?
Offline Megy_ED30
Re: ED30 brake pads
« Reply #4 on: July 15, 2011, 10:13:51 am »
Not every time.  Car needs to have done a few miles before it starts, then pretty much every time you brake, including just pressing gently on the pedal and getting no braking action to feel.  Brake pads could have been a good un, but not if they are the same.  Still thinking about the r32 setup too.
I thought it was coming from in the car, around the brake pedal area, but was driving last night with windows down and was definately from outside.  Google search shows an old thread on here mentioning sub frame bolts and a kit you can get, 2 new bolts and 2 shims, so might have to try that.
