Author Topic: Whats your idle speed?  (Read 6526 times)
Offline Rob GTI
« on: July 16, 2011, 04:10:43 pm »
After fitting my BSH Catch can I initially had an erratic idle due to a leak which was promptly sorted. Since then I've noticed the car idles at 720 - 760 rpm according to VCDS or 800rpm on the needle of the dial. Its not lumpy or causing vibrations, its just I can't remember what it idled at before and don;t want to go back to OEM PCV to see if thats anything to do with it  :laugh:
GTI Edition 30 No. 907, 3 door, Black. (Now Sold)
Re: Whats your idle speed?
« Reply #1 on: July 16, 2011, 04:19:07 pm »
750 here off memory, going for a drive soon will update  :happy2:
WILLZIE
« Reply #2 on: July 16, 2011, 04:22:06 pm »
800 RPM  :smiley:
« Reply #3 on: July 16, 2011, 04:25:15 pm »
Rob would you mind noting your oil consumption now using the PCV fix?
Many thanks
Offline Rob GTI
« Reply #4 on: July 16, 2011, 04:33:19 pm »
Will do its only been on a week and done less than 100miles. Going for a big run in it next week - say 500 miles(going S2+ as well) so will report back then, oil is to the max line at the min so will be interesting to see if it uses any.
Have you had any issues with consumption, I guess it may use more as more crap gets stuck in the can??
« Reply #5 on: July 16, 2011, 04:34:51 pm »
Have noticed higher consumption and will be happy if I can nail it to the catch can as that's obvious and understandable.
ST2+  :party: :party:  What software / garage?
Offline Rob GTI
« Reply #6 on: July 16, 2011, 04:39:05 pm »
REVO @ REVO HQ - getting the linear map and the select plus set with three settings - fast road, economy for motorways and wife mode  :laugh:
Offline Rob GTI
« Reply #7 on: July 17, 2011, 09:38:54 am »
It seems my idle speed is normal then.....anyone else confirm theirs and whether theirs is modded or standard?
Offline Frenzy
  • -Receive: 29
« Reply #8 on: July 17, 2011, 12:42:15 pm »
Unmodified: mine idles at just over a 1000rpm at cold and the 800 when warmed up. I do however get the faintest of shake.
I test drove a GTI about a month ago which idled at 900rpm without a murmur or shake whatsoever. I want mine to be like that but having raised it with the stealers a technician supposedly advised that it's fine at 800rpm and the slight shake is nothing - i only say supposed because i haven't heard the words out of the technician's mouth but via a sales rep. May be this is so but I'm generally untrusting of sales people - no offence to any sales people  :laugh:
Offline cupra_k1
« Reply #9 on: July 17, 2011, 01:04:59 pm »
My liquid gauge and VCDS show that my cars idle fluctuates between 720-760rpm with the aircon switched off and 800-840rpm with it switched on.
Offline Rob GTI
« Reply #10 on: July 17, 2011, 01:36:59 pm »
Thanks for the replies peeps, it was me just being paranoid  :laugh:
« Reply #11 on: July 17, 2011, 01:40:40 pm »
Love for your tuned motor will do that to ya  :stupid:  :sad1:
Offline Weston
« Reply #12 on: July 17, 2011, 03:58:52 pm »
750-800 once warm
GTI going...
« Reply #13 on: July 17, 2011, 04:11:39 pm »
Startup 1000 - 1100  Warm 850
