Author Topic: New Can Gateway Coding Issue!!! Sorted Thanks Guys  (Read 4132 times)
Offline GLIDN
« on: July 17, 2011, 04:13:43 am »
Today I installed  a New Can-Gateway from 1K0 907 530 E to a 1K0 907 530 AD.
Or rather should I say I'm busy installing it.
Ok I'm having a few issue's.
My Light for steering wheel stays on in orange, Light bulb indicator stays on (checked no lights blown), ESP no longer works and TPMS now complains too.
However if I use Long coding, I have no mention of Navigation (RNS510) or anything to do with the radio.
The old controller you can log into long coding enable or disable the radio.
The System appears to be setup for DSG but I have manual, So trying to figure out where to change that. in the MK4 it was in the cluster, but this appears to be in the Can-Gateway?
I'll post the error list on the next post to modify and delete as required.
It's complaining the TPMS can no longer be reached, Plus all these other errors on engine and a few others I never had.
All part of the learning I guess.
Lastly, it shows there is only one key coded to the car, however both my keys are working locking/unlocking and starting.
« Last Edit: July 17, 2011, 01:25:18 pm by GLIDN »
Offline GLIDN
Re: New Can Gateway Coding Issue!!! Help??
« Reply #1 on: July 17, 2011, 04:14:16 am »
VCDS Version: Release 10.6.4
Data version: 20110418
Sunday,17,July,2011,16:15:34:44293
Chassis Type: 7N0
Scan: 01 03 08 09 15 16 17 19 25 2E 42 44 46 52 55 56 62 72
VIN: WVWZZZ1KZ5U017588   Mileage: 82330km/51157miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine        Labels: 06F-907-115-AXX.lbl
   Part No SW: 1K0 907 115     HW:
   Component: 2.0l R4/4V TFSI G00 0070
   Revision: --H01---    Serial number: VWZ7Z0D1262564
   Coding: 0403000318070160
   Shop #: WSC 63670 981 92918
   VCID: E3CEE1A75BC5
No fault code found.
Readiness: 0110 0101
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0104
   Coding: 0004738
   Shop #: WSC 00046 412 00000
   VCID: 3A70FCC30CCF
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 1K0 907 044 AB
   Component: ClimatronicPQ35 066 0404
   Shop #: WSC 00000 000 00000
   VCID: 67D675B72FFD
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 1K0 937 049 N    HW: 1K0 937 049 N*
   Component: Bordnetz-SG     H34 0803
   Revision: 00H34000    Serial number: 00000001342101
   Coding: E78F0F0600041800001400001400000000087F075C
   VCID: 3A70FCC30CCF
   Part No: 1K2 955 119 B
   Component: Wischer VW350  012  0401
   Coding: 00049109
   Shop #: WSC 00000
   Part No: 1K0 955 559 M
   Component: RegenLichtSens 005  0605
   Coding: 00218142
   Shop #: WSC 00000
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 E    HW: 1K0 909 605 E
   Component: 3J AIRBAG VW8R  024 6300
   Revision: 03024000    Serial number: 0037KD00JYHR
   Coding: 0013130
   VCID: 2E58C093C087
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 F    HW: 1K0 953 549 F
   Component: Lenksäulenmodul 021 0050
   Coding: 0000042
   VCID: 356AEFFF25D1
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1K6 920 860 E
   Component: KOMBIINSTRUMENT VDD 0812
   Coding: 0005503
   Shop #: WSC 00090 824 59817
   VCID: 3064DEEBDAB3
Address 19: CAN Gateway        Labels: 7N0-907-530-V1.clb
   Part No SW: 7N0 907 530     HW: 1K0 907 951
   Component: J533  Gateway   H27 5603
   Revision:   H27       Serial number: 200910F2001169
   Coding: E9817F0600021200000003
   Shop #: WSC 12345 321 54321
   VCID: EDDA879F8D01
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VDD 0812
   VCID: 3064DEEBDAB3
Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
   Part No SW: 5N0 035 342 B    HW: 5N0 035 342 B
   Component: SG EXT.PLAYER H13 0090
   Revision: A1001003    Serial number: 7667846973
   Coding: 010000
   Shop #: WSC 01357 011 00200
   VCID: 264838B3E877
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX1.lbl
   Part No: 1K0 959 701 G
   Component: Tuersteuergeraet 09 0148
   Coding: 0000054
   Shop #: WSC 00046 000 00000
   VCID: 3260D4E3D4BF
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 H
   Component: EPS_ZFLS Kl.0       1502
   VCID: 3162DBEFD1B9
1 Fault Found:
00778 - Steering Angle Sensor (G85)
            000 -  -
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 BN
   Component: 01 KSG              0301
   Coding: 80C802087F2D8404085F01E010
   VCID: 7DFA37DF5D61
   Component:   Sounder n.mounted
   Component:       NGS n.mounted
   Component:      IRUE n.mounted
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX1.lbl
   Part No: 1K0 959 702 G
   Coding: 0000054
   VCID: 336ED1E72BA5
Address 55: Xenon Range        Labels: 1T0-907-357.lbl
   Part No: 1T0 907 357
   Component: Dynamische LWR      0002
   Coding: 0000003
   VCID: F4EC92FBEE2B
Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 1K0 035 186 AA    HW: 1K0 035 186 AA
   Component: Radio RCD310  016 0049
   Revision: 01000000    Serial number: VWZ1Z2K8170327
   Coding: 0000040004
   Shop #: WSC 00066 000 00000
   VCID: 65CA7FBFD5F1
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN1.lbl
   Part No: 1K0 959 703 C
   Component: Tuersteuergeraet 06 0213
   Coding: 0000016
   VCID: 3064DEEBDAB3
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN1.lbl
   Part No: 1K0 959 704 C
   Coding: 0000016
   VCID: 3162DBEFD1B9
End   ---------------------------------------------------------------------
« Last Edit: July 17, 2011, 05:15:25 am by GLIDN »
Offline GLIDN
« Reply #2 on: July 17, 2011, 04:43:53 am »
Error List updated with new coding. Man this is little daunting really.
Strange things is I have TPMS but double checking settings my old Can-Gateway list did not have TPMS enabled. :confused:
Offline GLIDN
« Reply #3 on: July 17, 2011, 05:17:41 am »
Ok, I have got rid of all the error messages
 bar the G85 Steering Sensor, Hopefully taking the car for a drive will reset and fix the problem.
Just need to figure out what is going on with the TPMS.
Can anyone with access to ETKA, have a look what parts are required, so I can double check all the parts are there.
Offline four!
« Reply #4 on: July 17, 2011, 07:02:42 am »
just done mine, I also had the steering faults but they went away when i drove it. remember seeing something about an adaption procedure. new to this myself so not sure if this would be what you need.
good luck
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #5 on: July 17, 2011, 07:30:15 am »
The TPMS option in the can gateway is for a separate module with sensors in the wheels and not the passive one found on the UK spec Mk5's (which is coded as part of the ABS controller)  :happy2:
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #6 on: July 17, 2011, 10:15:17 am »
Is it sorted?
Stu...
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #7 on: July 17, 2011, 10:17:41 am »
slightly off topic, I see from the scan that you don't have a factory alarm. Are you located in the UK
Cluster and Key coding
Location Great Yarmouth
Offline GLIDN
« Reply #8 on: July 17, 2011, 01:24:58 pm »
Is it sorted?
It appears to be all sorted now thank you. As mentioned, I took the car for a drive and it all came right.
Bummer part is my battery ran flat. (thanks to RCD310 and old Can-Bus) Might need to replace the battery.
Nope in New Zealand, Car is originally from Japan.
No factory fitted alarm, But would not mind installing it thou.
Thanks for all the quick replies and offered help.
