Author Topic: MDI  (Read 3352 times)
Offline GLIDN
Re: MDI
« Reply #15 on: July 29, 2011, 02:59:07 am »
Mine is the same too - won't accept coding to disable the aux in. If it weren't for vcds I'd be unaware as in all operational respects everything is fine.
is your MDI factory fitted? or did you install the MDI?
Do you have the glovebox version or centre console MDI?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: MDI
« Reply #16 on: July 29, 2011, 06:57:38 am »
another option is to fit the aux-in socket
fairly cheap and easy to do
Cluster and Key coding
Location Great Yarmouth
Offline alackofspeed
  • -Receive: 24
Re: MDI
« Reply #17 on: July 29, 2011, 07:50:33 am »
I have a 2007 MY GTI with RNS510-Cand MDI (can't recall the code, but it was brand new from VW only days ago) behind the dash.
Offline GLIDN
Re: MDI
« Reply #18 on: October 26, 2011, 04:23:45 am »
Finally pulled all my MDI kit out, I have no wires disconnected/unconnected in the Loom.
However we install my whole kit into a passat last week. As soon as the VW Factory bluetooth kit wiring was added to the MDI loom and daisy'd off the MDI Can-gateway wires.
We found funny errors codes in VCDS under the MDI kit.
Hope this helps.
