Author Topic: Lean Fuel Issues after 4k rpm on Revo Stage 2+ Ed30  (Read 90138 times)
Offline ukdub
Re: Lean Fuel Issues after 4k rpm on Revo Stage 2+ Ed30
« Reply #255 on: July 13, 2009, 05:17:37 pm »
Ah.  Should read more carefully.  Where is the high pressure sensor fitted?
Laser Blue with K04 power, APR hardware controlled by REVO 2+ software
Chassis by KW V3's, Whiteline and a hint of PRO race 1.2's
Brakes by Brembo 4 pots
Offline SteveS
« Reply #256 on: July 13, 2009, 06:23:53 pm »
that i do not know :p
SOLD!! :(
VW GTI Edition 30 No. 0551
Revo Stage2+ (LT) | Evoms Intake, K&N Filter | VWR LSD | Milltek R32 TBE | VWR Engine Mounts | VWR Big Front & S3 Rear Brakes | VWR Springs |  VWR Shortshift | SuperPro Bushes |  Recaro Seats
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #259 on: July 13, 2009, 09:14:39 pm »
Is the one on the pump not the low pressure one Hedge??
Can I go 50:50 or phone a friend? :laugh:
Not sure to be honest. It could well be the other one in the pic or it will be on the rail itself. :ashamed:
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #260 on: July 13, 2009, 09:23:28 pm »
I would think it would be the one on the rail as Nadeem had a new APR pump and JKM's report says it was like it from the factory in his car so it's not likely to be the one on the pump  :wink:
« Reply #261 on: July 13, 2009, 09:36:32 pm »
Keith did put a picture of one in his report. :smiley:
Offline cuprak1
  • Cupra k1 - 360 bhp/360 ft-lbs
    • London web design
« Reply #262 on: November 20, 2009, 10:39:47 am »
Nadeem,
I'm glad you've finally got your car back, working correctly. Just to answer some of your points;
We have Edition 30's running Stage2+ software in numerous regions around the world that have been for a long, long time now. This software was tested prior to release on numerous different cars, I believe at the time you had it on your car there was only Jonny running it in the UK market.
I have a copy of JKM's report on your car. The long and short of this is your car has at some point had an incorrect sensor fitted to it, this is the cause of the problems. Stage2+ software utilises the potential from installing a high pressure fuel pump, up until the point you had Stage2+ installed the problem could have gone unnoticed as the car wouldn't have been running at as higher fuel pressure.
We have always known there is no issue with our software on the car. Since your problems appeared we have been in communication with JKM giving them any further information we could to help solve the issue. We've gone out of our way to help them rule out components/software by way of assessing maps we already knew to be 100% fine, going through both their and NMS logfiles to confirm the correct files have been used, and offering any ideas we had to them. At no point have we
We build our software to suit a certain specification, your car had been altered (by whom we don't know) from this and that was the cause of the problems. If we had made a mistake it would have been evident on every single Stage2+ car that runs our software. This isn't the case and so you're aware fuel pressure has been checked on more than just your car. As per the report your car (for some reason) had an incorrect sensor on it.
We are a software development company, not a diagnostic service. To be expected to diagnose an issue that's not related to our software without even seeing the car is completely un-reasonable. We can only do so much by offering advice and ideas to our dealers and customers in a scenario like this when there is an issue with a component on the car.
I've spoken with trade parts and they do list the incorrect sensor for the ED30. Now your problem has been diagnosed I would advise having your stage2+ re-installed which will allow you to get out there and enjoy the full potential of your car!
Good reply :)
I am thinking my car has this incorrect sensor, does any one have the part numbers for the good and bad sensor?
SpeedStats iPhone app  - AVAILABLE NOW!
View my Cupra k1 project thread here! 360is
« Reply #263 on: November 20, 2009, 10:45:45 am »
I understand VW have revised their parts catalogue after this episode.
Unless it is somewhere in this thread (no I'm not looking for you  :P) it might either be worth a call to JKM or a dealer.
Part numbers in here. http://www.mk5golfgti.co.uk/forum/downloads/illyun2.pdf
« Last Edit: November 20, 2009, 10:49:04 am by Hedge »
Offline Poppa Dom
« Reply #264 on: November 20, 2009, 10:47:48 am »
Best to talk to JKM, howvwer Keith is away on his honeymoon at the moment and is away until mid/late December. I do know that mine has the correct part as they compared my car to Nadeems as they had them both there at the same time. I'll trawl through my emails and see if Keith did actually tell me what it was for you.
Offline cuprak1
    • London web design
« Reply #265 on: November 20, 2009, 11:10:53 am »
Nice one people  :congrats:
Offline Revo Kev
« Reply #266 on: November 20, 2009, 11:12:57 am »
I believe it should be part # 06J 906 015B (the incorrectly listed part number that was being fitted from the dealers incorrectly was 06H 906 051A).
Where seen in the past there have been two faults logged as well - 004506 and 008567
Offline cuprak1
    • London web design
« Reply #267 on: November 20, 2009, 11:14:12 am »
Ok going to check mine tonight  :congrats:
Offline Poppa Dom
« Reply #268 on: November 20, 2009, 11:28:29 am »
Correct  :happy2:
Offline cuprak1
    • London web design
« Reply #269 on: November 20, 2009, 11:37:12 am »
so if my car has this old sensor i should get the new one and what if that still doesnt solve my flat spot issue?  :popcornsoda:
