Author Topic: Lean Fuel Issues after 4k rpm on Revo Stage 2+ Ed30  (Read 94591 times)
Offline cupra_k1
Re: Lean Fuel Issues after 4k rpm on Revo Stage 2+ Ed30
« Reply #270 on: November 20, 2009, 12:43:32 pm »
I just checked mine. The part number i have is 06E 906 051 K and i haven't encountered any lean running issues.....
Offline cuprak1
  • Cupra k1 - 360 bhp/360 ft-lbs
    • London web design
« Reply #271 on: November 20, 2009, 12:45:39 pm »
do you have revo code or any mods?
SpeedStats iPhone app  - AVAILABLE NOW!
View my Cupra k1 project thread here! 360is
Offline cupra_k1
« Reply #272 on: November 20, 2009, 12:55:12 pm »
Yes mate. Stage 2+ with all the required bits bar the intercooler. I used to get a missfire at around 6krpm until i fitted the milltek DP which completely solved the issue and its ran sweet as a nut ever since. My cars on a 58 plate just to clarify.
Offline cuprak1
    • London web design
« Reply #273 on: November 20, 2009, 12:57:08 pm »
06E 906 051 K seems to be a later revision than the ones having issues so i think your fine mate..
where are you in the country would be good to compair K1s :) you coming to the rr day?
Offline cupra_k1
« Reply #274 on: November 20, 2009, 01:07:07 pm »
I'm in the Midlands. I've not put my name down for any rolling road days yet. Which one is that?
Offline cuprak1
    • London web design
« Reply #275 on: November 20, 2009, 01:17:17 pm »
next sat 28th - http://www.mk5golfgti.co.uk/forum/index.php?topic=7178.0
Offline CarrG
« Reply #276 on: November 20, 2009, 01:18:06 pm »
What intake have you got mate? (Sorry if you've posted it and i missed it).
I get the odd misfire at top end and have been wondering if its my Dbilas intake.
K1 Revo 2+
Ibis RS3
Offline cupra_k1
« Reply #277 on: November 20, 2009, 01:47:55 pm »
I have a Dbilas intake too. I know a few people have mentioned lean issues with the Dbilas, but i modified mine a while back by inserting a custom made 67mm id sleeve inside the maf section. The fuel trims are pretty much bang on now.
Offline CarrG
« Reply #278 on: November 20, 2009, 07:18:26 pm »
Ah good info cheers i'll try it.  :happy2:
K1 Revo 2+
Ibis RS3
« Reply #279 on: November 20, 2009, 07:25:35 pm »
As I posted recently in another thread: An aftermarket high-flow tubular intake can result in the ECU actioning fuel cuts and this can be further contributed to by running a high boost setting.
But, of course, every car is different, has different mods, and nothing is simple!
Offline ukdub
« Reply #280 on: July 17, 2011, 11:39:04 pm »
Did Nadeem ever replace the sensor that could of been fitted wrong at the factory, and if so did he go back to stage 2+ ?
Laser Blue with K04 power, APR hardware controlled by REVO 2+ software
Chassis by KW V3's, Whiteline and a hint of PRO race 1.2's
Brakes by Brembo 4 pots
« Reply #281 on: July 17, 2011, 11:41:09 pm »
Yes I believe so.
Offline Joesoap
  • -Given: 17
  • Homeless
« Reply #282 on: September 18, 2013, 03:28:06 pm »
I'm melted after read that   :rolleye:
Has to be Grey
Revo,milltek,Bilstein,AP's,Ths mounts,dbilas, Sorted
