Author Topic: DRL Controller Help!!  (Read 1336 times)
Offline CocoPops
    • Kennet Heath
« on: July 18, 2011, 04:17:19 pm »
Right,
So I have a strange issue....
I have the following DRL controller (see instructions below).
When I first plug the controller into the battery, the DRLS light up for a 2 second self test.
But when I connect the "For "+" Signal Control to a 12v feed", the DRLS do not come on.
So, am I missing something obvious?
I'm using a fuse tap, to take a switched live off the fuel pump fuse. (ie when the fuel pump is on, the 12v feed is live).
I've even tried connecting the signal control wire to the 12v + side of the battery, no joy.
This is the 2nd DRL controller I've had, thinking the first one was faulty, but I guess I'm doing something wrong as they are both the same.
Regards,
Lee.
« Last Edit: July 18, 2011, 04:23:54 pm by CocoPops »
Used to Own: 2008 GTI Ed30 | ITG Intake | Miltek TBE System | Bluefin Stage 2 | 327bhp
On Order: 2017 Golf GTI Performance Pack 5dr DSG
Also own: 2016 Lotus Evora 400
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: DRL Controller Help!!
« Reply #1 on: July 18, 2011, 09:09:57 pm »
Lee,
So far as I can see you'll want the +ve & -ve battery terminals connected to supply power to the lamp.  Next you want the +ve & -ve DRL connected to the DRL lamp. The only one in question is the sensing wire which can be set to +ve or -ve by swapping the inline crimped connector over.  I would think that if you have the +ve connected to a 12v source it should allow the lamps to operate.
I think Position Light is Side Light.
Stu...
