Author Topic: upgrading my soundsystem  (Read 5077 times)
Offline badly_dubbed
  • Mk5 Steel Grey R32
Re: upgrading my soundsystem
« Reply #15 on: July 19, 2011, 02:37:29 pm »
Cheers every one will look into tht 4 channel amp for the components
Maybe a daft question but as the front are 3 way won't i require a 6 channel?
« Reply #16 on: July 19, 2011, 02:38:32 pm »
The 3-ways will have a crossover to split the frequencies. They only require a single input.
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=migvmhqa4timg6118ffkdi8r89&/topic,19740.0.html
« Reply #17 on: July 19, 2011, 02:41:17 pm »
it will if there higher watted but the speakers is onli the beginning in my plan  :evilgrin: :evilgrin:
Oh dear.  :confused:
If you haven't added any more voltage or increased the amount of current drawn how will the power increase? :confused: :confused:
What you can do is buy more sensitive speakers. This means the actual cone moves more for a given input but you can't invent power. :scared:
Phew... i thought i was going mad!  :signLOL:
Do the Hertz fit in without hacking bits off etc? I presume you get both left and right when you buy those?
Offline Gti_Mad
« Reply #18 on: July 19, 2011, 03:23:53 pm »
^^^^^ i can invent power mr hedge  :evilgrin: :evilgrin:
and most stereos give out a decent output that by changin speakers gives a better sound ask mr wolf he upgraded his speakers and said it sounds so much better  :P :P :P
« Reply #19 on: July 19, 2011, 03:44:48 pm »
Yes I agree it will 'sound' better but you intimated that because the speakers were "higher watted" that they would give more power.
Sadly not.  :popcornsoda:
« Reply #20 on: July 19, 2011, 03:47:43 pm »
 intimated
Isn't that what people from Norfolk do.  :wink:
« Reply #21 on: July 19, 2011, 03:50:12 pm »
 :signLOL:
Offline Gti_Mad
« Reply #22 on: July 19, 2011, 03:57:37 pm »
Oh my had for wording ir wrong  :innocent:
« Reply #23 on: July 19, 2011, 08:13:00 pm »
so a 4channel amp will do my front and rear components?
« Reply #24 on: July 19, 2011, 08:13:59 pm »
  • -Receive: 291
« Reply #25 on: July 19, 2011, 10:34:43 pm »
I have the HSK163 setup in the front. The RNS510 limits some output to "protect" the stock speakers as they're so crap. Swapping them has made a vast difference but this is mainly in clarity and allowing me to increase the volume/bass without distortion as used to happen with the stock setup.
Next step is definitely an amplifier.
Offline Megy_ED30
« Reply #26 on: July 20, 2011, 12:31:43 pm »
This thread has been good for me also, I am now going to buy a set of the 3 way component speakers in the original post and try to build myself one of the fitted sub boxes for the boot, both running off a 4 way amp (bridged for the sub in the boot).
Anyone got a link to a guide for removing the door cards at all?
07 Plate GTi ED30 DSG - Grey - Standard (but not for long)
Offline StephenED30
  • -Receive: 53
  • Edition 40 No 135
« Reply #27 on: July 20, 2011, 11:13:49 pm »
