Author Topic: Fuel Pump Question TFSI MK5 - Removal  (Read 4853 times)
Offline GLIDN
« on: July 19, 2011, 11:51:01 am »
So I know how to remove my pump that is not the issue.
But looking at this post on MK5GolfGTI
http://www.mk5golfgti.co.uk/forum/index.php/topic,8339.0.html
Look at picture 4. Now this pump has a pressure relief valve.
Well sorry to say but mine does not.
So My Question is as follows.
Once I removed the battery etc. How do I release the pressure in the pump to save myself a face full of petrol?
Re: Fuel Pump Question TFSI MK5 - Removal
« Reply #1 on: July 19, 2011, 09:21:05 pm »
If you don't have a schrader bleed valve here then just slowly and carefully unscrew the brass fitting till you hear a hiss, then stand back and let the pressure bleed off over a few minutes before proceding. It's wise to put a rag as shown to absorb the petrol that will come out.
« Reply #2 on: July 19, 2011, 09:32:39 pm »
That's an unusual way to fix PCV issues  :grin:
« Reply #3 on: July 19, 2011, 09:37:53 pm »
 :signLOL:
Offline GLIDN
« Reply #4 on: July 19, 2011, 11:27:33 pm »
thanks for that, Will give that a try within the next day or so. If I get a chance otherwise the weekend it will have to be. :happy2:
Haha, good spotting.  :grin:
Still wondering If I'm removing the pump, I may as well install HPFP while I'm there. Hmmm decisions, decisions.
« Reply #5 on: July 20, 2011, 09:00:24 am »
If removing the pump, take extra care when trying to disconnect the electrical connector from the top of the pump as the plastic piece on the pump is not robust.
Offline Cupra R
  • -Given: 18
« Reply #6 on: July 20, 2011, 09:12:26 am »
Best way I have found with any of the Electrical Plugs is to push them on a little further, then release the catch.  Seems to work everytime for me.  :happy2:
Offline GLIDN
« Reply #7 on: July 23, 2011, 06:41:59 am »
Done mine this afternoon, was pretty easy. No leaking fuel which is always a good thing.
But did find a hair line fracture across the sensor on top?
I guess pump replacement?
Otherwise I had a banjo fitting and nut for the bottom two connections. Will post photo's to orris sometime.
« Reply #8 on: July 23, 2011, 10:48:19 am »
Not absolutely necessary as lots of guys in the US have this problem and run without issues.
Offline baldwined30
« Reply #9 on: July 23, 2011, 12:22:15 pm »
SLight high jack but whilst were on the subject of pumps, has ANYONE noticed a different sort of higher pitched noise coming from the HPFP area when accelerating?
Im worried its not fitted properly! I feel i can hear it more at the moment but that prob because i have just fitted a twintake and removed the engine cover! any help is much appreciated!
Ed30
Offline GLIDN
« Reply #10 on: July 24, 2011, 12:03:21 am »
Can you describe the sound a little better? It sounds to me like the harmonics that presents itself with some intake kits.
But in all honesty it appears to be car specific more so than the intake kit itself.
Offline baldwined30
« Reply #11 on: July 24, 2011, 12:07:24 am »
It was making a smallish high pitched sound when i accelerate and stop when i was either up to speed or stopped accelerating but it happened before the intake was put on. im gonna change the cam follower on Monday to see if that helps!
Ed30
