Author Topic: Re-setting the 'Tyre montior display' light on dashboard?!  (Read 3283 times)
Offline DSGAndy
  • TR MKV Golf GTI DSG
« on: July 19, 2011, 09:14:22 pm »
Does anyone know how to do this - or the steps needed to remove the light?!
The light popped on going round a roundabout.  Had a little check of the tyres, wear n tear / pressures etc all seemed fine!  :confused:
A freind driving a ED30 said it was easily re-settable - his method has thus far not worked!?
.... and is it possible there is a larger problem than i first anticpated.  Are there common errors with the sensors etc etc?  Any help much appreciated...
Thanks.
"Standard for the time being"....
Offline Poppa Dom
Re: Re-setting the 'Tyre montior display' light on dashboard?!
« Reply #1 on: July 19, 2011, 09:15:14 pm »
Press and hold the button until it goes off  :happy2:
« Reply #2 on: July 19, 2011, 09:23:25 pm »
You should also hear a bong doing the above.
  • -Receive: 291
« Reply #3 on: July 19, 2011, 09:48:00 pm »
Because it's a passive system, working on the rolling circumference (I think) of the wheel, any variation can set it off - new tyres, different alloys, lower pressures etc - all mean the system needs to be "reset".
Offline DSGAndy
« Reply #4 on: July 19, 2011, 10:21:06 pm »
Excuse my ignorance..  eaxctly what button?
FYI - I have already held the reset button on the indicator lever for well over 20secs - NO joy?!
  • -Receive: 291
« Reply #5 on: July 19, 2011, 10:23:58 pm »
Wtf? The reset button is next to the gear lever. Next to the esp button!!
« Reply #6 on: July 19, 2011, 10:36:39 pm »
I suspect he is looking at the cruise control reset button.
  • -Receive: 291
« Reply #7 on: July 19, 2011, 10:40:23 pm »
I thought it was the one that controls the MFD - allows you to reset lifetime mpg/average mpg etc.
« Reply #8 on: July 19, 2011, 10:50:48 pm »
Could be, but I was thinking about  the cruise control on the left stalk has a set and reset switch at the end of the stalk.
Offline PND
  • -Receive: 62
« Reply #9 on: July 19, 2011, 10:58:41 pm »
@DSGAndy.. this is the 'SET' button you're looking for..  the one with the symbol on that looks fairly similar to the warning light on the dash!  :happy2:
No questions are too daft on here.. that is what this place is for!
Offline LouCyffer
  • -Given: 36
  • -Receive: 63
« Reply #10 on: July 20, 2011, 08:12:19 am »
Also, remember that everytime you check pressures, add a little air or, as Stealth says, remove the wheels for any reason, always reset with the above button  :happy2: When you hear the 'bong' you're light will extinguish & you're good to go.
Offline Betty02
    • iBett
« Reply #11 on: July 20, 2011, 08:16:57 am »
Think mine might of broke actually, I had 17's on months back, went to 19" Omanyt Reps with different tyres, sold them back to 17's and then to my Monza 2 Reps with new tyres and it never came on once? Normal :S
it has been on in the past when I hit a put hole when I first got the car? Any ideas on how to check it chaps? Common fault?
Sorry for the hijack!
ADMIN NOTICE: Please do not use the site for advertising!
Offline LouCyffer
  • -Given: 36
  • -Receive: 63
« Reply #12 on: July 20, 2011, 09:09:18 am »
@Betty02 you should try VCDS scan. The system works by detecting a change in rolling resistance of one or more tyres as compared to the others. In a puncture, the rolling resistance increases at the affected corner & the system will see this & alert you. I think it uses the ABS sensors for this.
If all four wheels are changed & the rolling resistance of all are the same it can 'fool' the system into thinking there is no change, as no differential is noted between all four. I ve forgotten to reset after changing to winter tyres & wheels and it was several days before I got a warning.
The chances of the driver not noticing 4 punctures is very low, so that is why a comparative method is used. It isn't a true pressure monitor, in that is doesn't physically measure the inflated pressure, just the rolling resistance when you tell it with the button that pressures are correct. A deviation too far from your 'set' normal will alert the system.
« Last Edit: July 20, 2011, 09:12:38 am by LouCyffer »
Offline DSGAndy
« Reply #13 on: July 20, 2011, 04:37:26 pm »
Yeh fellas! It was the crusie control reset button.  Tbh I thought it was a little odd when my mate (respected car journo for Parkers) told me that was the button to reset it - or at least it was for him on his ED30..  ??
Thanks for the help.  - How the f@#k I missed the reset button next to ESP button I'll never know  :ashamed:
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #14 on: July 20, 2011, 04:46:10 pm »
Interested to know ho it actually works though, like where are the sensors? same sensors used as the abs/esp?
Diesel Daily Hack.
