Author Topic: Side Skirts Cost - Am I being quoted too much?  (Read 6207 times)
Offline big al
Re: Side Skirts Cost - Am I being quoted too much?
« Reply #15 on: July 26, 2011, 10:59:25 am »
The skirts are no different on a 3 door to a  5 door.
And no, I don't think you do need the fitting kit, just buy some bonding/adhesive and you should be fine. (also 4 screws that go underneath and in the wheel arches.
Offline vRS_Pagey
  • -Receive: 59
« Reply #16 on: July 26, 2011, 11:27:22 am »
Do the underneath screws go in to the body?
Offline JulioTDI
« Reply #17 on: July 26, 2011, 05:03:20 pm »
No you use the side skirt adaptors listed in the first post. You need four of them and the clip into some holes in the chassis once you remove a rubber bung. You then screw into a pre drilled hole to secure the skirt from the bottom. I then used some bonding adhesive, ran a bead all the way along the length of the skirt below the sticky foam strip, removed the tape on the sticky foam strip and done. Still on!
2016 Mk7 Golf GTE 1.4 TSI 204PS PHEV
Past: 2008 Mk5 Golf GT Sport 2.0 TDI 140PS
Offline sf1506
« Reply #18 on: July 27, 2011, 09:46:51 am »
I'm still unsure about part numbers I've got 3 different lots now??
Offline martinbickley
« Reply #19 on: July 27, 2011, 10:00:50 am »
Smith Knight Fay in Stockport have confirmed to me that code 1K4 is for a 5 Door MK5.
You might want to confirm the same with your local dealer before ordering.
Martin
Offline sf1506
« Reply #20 on: July 29, 2011, 09:21:32 am »
I'm going to order these today and could do with a bit of advise in which are the right ones??
I've got a 5 door.
I've got different part numbers to you?? Mine are -
1k3853859b9b
1k385386099b I think these are for a 3 door
And
1k5853859b9b
1k585386088b I think these are for a 5 door???
1K4 853 859B9B9 (Left Side Skirt) - £37.00
1K4 853 860B9B9 (Right Side Skirt) - £37.00
« Reply #21 on: July 30, 2011, 12:39:29 am »
Fitted my skirts today.  Look good, pictures to follow.
Martin
« Last Edit: July 31, 2011, 09:39:03 pm by martinbickley »
Offline HARWOODANDY
« Reply #22 on: August 05, 2011, 12:40:06 am »
Try these?
http://www.eurowagens.com/en/vw/golf-5-jetta-5/mouldings/oem-door-sills-vw-golf-5-gti-set-1.html
Not sure if they include all the bits, but by the sounds of it you don't need all the fitting kit etc anyway - if it worked for Demon666 then i'd go along with that.
« Reply #23 on: August 05, 2011, 12:54:19 am »
Try these?
This is just for the skirts, cheaper to buy from the dealer.
I just used the skirts and adapters which plug into the bottom of the car.
The adapters hold the skirts in place at the bottom and stop them flexing.
Martin
Offline HARWOODANDY
« Reply #24 on: August 05, 2011, 10:08:04 am »
So no drilling then?
Did you use any adhesive as well?
Any pics Martin
Andy
« Reply #25 on: August 05, 2011, 10:35:19 am »
Any pics Martin
Andy
Have put the pic above on.
No drilling and no adhesive other than the sticky strip already on the skirt.
Its screws in at both sides and also screws into the adapters at the bottom so its held on pretty good.
If it ever did start to come away at the top I would just use a bit of adhesive then.
The support strips which I didn't use have a lip on the top which the skirts tuck into, but as these need to be glued/screwed into the car I decided I may as well just glue the skirts if I ever need to.
Martin
Offline vRS_Pagey
  • -Receive: 59
« Reply #26 on: August 05, 2011, 08:48:15 pm »
Nice work buddy, so to recap, you ordered 2 x side skirts part numbers: 1K4 853 859 B9B9 (Left) 1K4 853 860 B9B9 (Right) 4 x Adaptors 1K0 853 493 and 4 x Screws N10354602?
Will you colour code them?
