Author Topic: Weird thing happened with car this morning? Any Advice?  (Read 1785 times)
Offline MJR
« on: July 25, 2011, 09:34:38 am »
Ok, my first day back at work for 7 months today lol
Up nice & early, all sorted for first day back & go out to the car to drive upto work.
Start the car as normal, all seems fine. Then as I start to drive off I get:
"Stop Engine, Oil Pressure Warning Light" comes on for a couple of mins then goes off again?
When I got to work, I checked the dipstick & oil level seems fine. So drove again for a bit & no more warning lights etc
So slightly confused as to what it could have been or still is?
I have noticed, although probably being paranoid now, that after I turn the car off, there is light smoke coming from my tailpipes (is that normal?) as I've never noticed it before.
Offline Conrad The Jellyfish
Re: Weird thing happened with car this morning? Any Advice?
« Reply #1 on: July 25, 2011, 10:53:01 am »
MIght be different, but i had this issue on my MK1 Audi TT 225.
Turned out, it was an air leak into an oil breather pipe after i didnt block it after ftting an aftermarket induction kit.
You running and after market filter?
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
« Reply #2 on: July 25, 2011, 12:02:18 pm »
My last GTI did same,oil light came on checked level & all was fine.Re-started & no light & it never did it again.
Offline Richn83
  • -Given: 49
  • -Receive: 85
« Reply #3 on: July 25, 2011, 12:05:29 pm »
The oil pressure sensor is located around the front of the engine by the oil pump, above the oil filter might be worth looking if you have any oil leaking from around this area as it could have caused pressure to drop until it was re-built up by the engine after starting.
psw mk5
« Reply #4 on: July 25, 2011, 05:53:32 pm »
Parked on a hill incline etc ?
Offline MJR
« Reply #5 on: July 25, 2011, 06:39:00 pm »
Well car has been fine all day since that weird incident.
Very strange  :stupid:
Booked the car in  at VW next month for a major service inc cambelt / water pump & also fitting cruise control  :happy2:
So should be all good after all the feckin miles I have done in the last few months  :laugh:
Offline MJR
« Reply #6 on: July 26, 2011, 09:13:58 am »
Well it happened again this morning just after start up,
Red light flashed on saying stop engine oil pressure fault, then after a min or so went out again & car drives fine.
Any ideas???
Offline MJR
« Reply #7 on: July 26, 2011, 04:48:03 pm »
Well same as yesterday lol did it once after start up this morning, stayed on for a min or 2 then vanished again,
had nothing else again all day and done a few trips in it lol
weird.com  :stupid:
Offline micky 32
« Reply #8 on: July 27, 2011, 11:50:56 pm »
Best case scenario could be a sticky pressure switch or worst case a failing oil pump which is not getting pressure up quick enough. Needs to be check ASAP.
2008 Octavia vRS K04'd , Forge twintercooler, Evoms, Autotech uprated pump, full Milltek exhaust 324bhp on JKM's rollers ;-)
Offline MJR
« Reply #9 on: July 28, 2011, 12:22:33 am »
its booked into VW on the 8th August  :happy2:
