Author Topic: Tfsi Mikes Money Pit :: AKS built Cupra :: TTE420 :: Rtech Tuned  (Read 748921 times)
Offline toosmiles
  • -Given: 22
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,92286.0.html
Re: Tfsi Mikes Money Pit :: APR / AKS Cupra ::
« Reply #2550 on: October 17, 2014, 12:01:04 pm »
Car goes down to AKS on Saturday :)
Booked the last trackday for this year too. Bit of a gamble on the weather :scared:
your car will be transformed mike,well jel on the track day,where you going?
Golf R mk6 R-tech tuned GTX3071r
Offline dom069
« Reply #2551 on: October 18, 2014, 06:24:04 pm »
Spent the last few days flipping through all hundred and seventy odd pages of this!
Always had a massive soft spot for these, yours is truly outstanding though :congrats:
BC Racing Coilovers : R32 Rear Bumper : Milltek Cat Back : R32 Rear Lights : S3 Brakes : Colour Coded Side Skirts : US Grill : 18" BBS CH : De-Wipered : Bluefin Remap : Pipercross Filter : S3 Short Shifter : Powerflex Wishbone Bushes : MK6 Steering Wheel : RCD510
« Reply #2552 on: October 18, 2014, 08:14:22 pm »
6157944
Thanks very much! I think I'm one of the few original Cupra owners left :( most have moved on to different motors. Had this from new in Jan 08 still more to come :)
Re: Tfsi Mikes Money Pit :: APR / AKS Cupra :: Inlet clean
« Reply #2553 on: October 22, 2014, 07:24:52 am »
Inlet valves at 70k;
 :sick: :sick: :sick:
« Last Edit: October 22, 2014, 07:27:53 am by Tfsi_Mike »
Re: Tfsi Mikes Money Pit :: APR / AKS Cupra :: throttle body pipe
« Reply #2554 on: October 22, 2014, 07:26:53 am »
Screamer pipe  :grin: :grin:
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #2555 on: October 22, 2014, 07:29:43 am »
I've seen worse valves on the forum, but those definitely needed a clean  :sad1:
Did you have any lumpiness at idle or any other symptoms of dirty valves?
« Reply #2556 on: October 22, 2014, 07:36:58 am »
Not particularly. Not as noticeable as when injector 3 needed replacing anyway, that was a hiccup at idle every couple of minutes.
Hopefully be smoother now anyhow.
Having custom/ AKS enlarged TB pipe, inlet clean, Runner flap delete, map update and WMI so hoping for a nice improvement  :jumping:
Also having new rear brakes (Alloy hubs & 330mm conversion is in the pipeline but not yet), HEL rear lines, new brake fluid, New PCV, Cam follower, 2 lhary noticeable (but very annoying) dents pulled, replacement spigot rings for the TDs, Red Forge TB hose, N80 & associated gubbins removed and a grind of the front rotors.
Offline b9rgo1234
« Reply #2557 on: October 22, 2014, 01:18:09 pm »
I had a look at the alloy hub conversion but with the width and the offset of the Turinis it pushed the wheels out too far on the Leon, the only option I saw was to try and widen the rear arches.  :sad1:
Offline dan930
  • -Receive: 56
« Reply #2558 on: October 22, 2014, 02:35:20 pm »
What do you mean by grinding the front rotors?
MK6 golfR dsg
AKS TUNED
NORTECH PERFORMANCE HTA3071
R TECH custom map
Offline vRSAlex
  • -Receive: 253
« Reply #2559 on: October 22, 2014, 03:01:06 pm »
Basically having them skimmed.
Follow AKS tuning on Facebook
« Reply #2560 on: October 22, 2014, 03:51:18 pm »
Alex is smashing through the jobs and reports that the Inlet clean & TB pipe have made a lovely difference mid range  :driver:
« Reply #2561 on: October 22, 2014, 04:45:13 pm »
Added UltraRacing rear under brace to the list  :innocent:
Offline toosmiles
  • -Given: 22
« Reply #2562 on: October 22, 2014, 04:50:33 pm »
Good mod this m8 :happy2:
« Reply #2563 on: October 24, 2014, 03:46:44 pm »
Car is having a software update today to add; left foot braking, hard cut limiter, Runner flap delete code, charcoal delete code should see a few extra ponies too
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
« Reply #2564 on: October 24, 2014, 05:08:20 pm »
Still APR map Mike? :)
Over the top mod list ;o)
