Author Topic: Tfsi Mikes Money Pit :: AKS built Cupra :: TTE420 :: Rtech Tuned  (Read 765962 times)
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
Re: Tfsi Mikes Money Pit :: APR Stage II+ Cupra ** Update page 110 ! **
« Reply #1665 on: September 19, 2012, 05:10:35 pm »
Sorry i haven't got the pm from JonnyC anymore, but here's a bit about the subject:
http://www.mk5golfgti.co.uk/forum/index.php/topic,7823.msg222742.html#msg222742
Over the top mod list ;o)
  • -Given: 380
  • -Receive: 442
« Reply #1666 on: September 19, 2012, 05:19:48 pm »
Ah! Understood  :drinking:
Lower position of ball joint = higher centre of roll.
TT arms also do this?
« Reply #1667 on: September 19, 2012, 05:21:59 pm »
How will the top mounts lower the roll centre, Jake? Cheers
  • -Given: 243
  • -Receive: 154
« Reply #1668 on: September 19, 2012, 06:59:39 pm »
actually, looking for the info from JonnyC i couldn't remember the argument for, but i'm sure the top mounts was bad compared to doing the tt lower arms. I'm just not sure why anymore  :grin:
Maybe Alex has some info on pro and cons for the top mounts??
Offline Janner_Sy
  • -Receive: 113
« Reply #1669 on: September 19, 2012, 10:52:06 pm »
it was something like top mounts pushed the roll centre away from the optimum level, but TT arms moved it towards it.  iirc he said something along the lines of having both allowed you to keep a good roll centre
« Reply #1670 on: September 20, 2012, 10:20:18 am »
This ^^^  Basically there is more benefit adding camber from the bottom than  the top. Wider track lower rolling centre, more contact patch bla bla. This being said i am guessing the differences would be minimal unless you could achieve lots of camber with both. Every little helps though when on track near the limit ( or your just a mad modder.  :laugh: )
  • -Given: 380
  • -Receive: 442
« Reply #1671 on: September 20, 2012, 10:29:13 am »
....We don't know any mad modders on here though, do we.
Though there's a lad called Mike with a Cupra..................
He is going to enjoy himself when he gets the opportunity to do trackdays more  :happy2:
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #1672 on: September 20, 2012, 05:29:38 pm »
I need to assume Jake is right:
When increasing camber by adjustable top mounts you also change the 'strut angle'
'SAI' (unfortunately I only know the German word 'Spreizung') at the same time.
This is the angle you see on the right picture and it's in the 15° area on a Mk.V GTI.
The point is this angle also defines the position of the roll center as shown above.
For maximum cornering grip more camber is more important.
 :wink:
I wouldn't overestimate this, but it seems Jake has set an interesting point on this.
 :congrats:
« Last Edit: September 20, 2012, 05:31:32 pm by the bruce »
"You get what you pay for."
Offline vRSAlex
  • -Receive: 253
« Reply #1673 on: September 20, 2012, 07:32:45 pm »
Did myself a little drawing.  Too good to publish but it helped me write this answer:
There is very little, and I mean very little change to the roll centre by using adjustable top mounts.  You are only moving the mount approx 15mm inboard which wont cause any noticable change in handling to a negative effect.
You will have more or a negative effect by keeping the rubber mounts as the mount moves so much before the damper can function.  For example, with the stock rubber mounts on the vRS I could push down on the front of the car and it would 'bounce' due the flex in the rubber.  Now with the Ground Control mounts fitted it wont flex at all.
« Last Edit: September 20, 2012, 09:32:12 pm by vRSAlex »
Follow AKS tuning on Facebook
« Reply #1674 on: September 20, 2012, 07:35:08 pm »
That satisfies me  :congrats:
Plus with both the lower arms and top mounts I will always have the full options on adjustability in the future  :smiley:
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #1675 on: September 20, 2012, 08:42:44 pm »
Keep in mind Mike's Cupra already has the TT/Cupra mounts which are 30 % stiffer.
 :wink:
On a side note:
If you want to increase camber significiently you need to shift strut mount a bit more
than 3 mm.
Don't get me wrong, I still believe this is no reason to worry, it's just an interesting point.
Also there's no alternative. If you want more camber you also get an increase in 'SAI'.
Otherwise you'd need different swivels.
« Last Edit: September 20, 2012, 08:44:26 pm by the bruce »
Offline vRSAlex
  • -Receive: 253
« Reply #1676 on: September 20, 2012, 09:33:12 pm »
I have edited so state its more like 15mm as I miss typed.
« Reply #1677 on: September 20, 2012, 09:35:05 pm »
What are the Dunlops I might be selling my testicles to order Alex?
Thanks for the update on the battery tray!  :party:
Offline vRSAlex
  • -Receive: 253
« Reply #1678 on: September 20, 2012, 09:45:56 pm »
Dunlop Direzza 03G tyres.  150 plus vat each iirc.
Go read some reviews.  I want some too.
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=gndgvpu460jc2iqvvupha7pm2g&/topic,19740.0.html
« Reply #1679 on: September 20, 2012, 09:48:20 pm »
Thats seems quite cheap... is that for 225 40 18?
