Author Topic: please help....mot fail  (Read 697 times)
Offline cass
« on: July 25, 2011, 07:31:26 pm »
Hi , im new to the forum so please go easy . I bought the car (golf gttdi  05 plate) last september and had to take it for its mot today......it failed. Reason was that the light pattern was all over the place . The car had a hid kit on when i purchased it and i have probably been dazzling drivers since then without knowing....the kit is a 35w 6000k but dont know what make it is . Ihave two questions really .....are they easy to adjust , or if the worst comes to the worst ...how do i remove them? i think the lights are standard(non zenon)and i can adjust the beam insde the car , hope i have explained myself clearly.....cheers mark
Re: please help....mot fail
« Reply #1 on: July 25, 2011, 07:59:45 pm »
If the headlight housing is still OEM then you will have a vertical and a horizontal screw on each headlight to set them at the correct height. Park approximately 1 metre away from a wall/garage door and check the pattern against it. The pattern should be horizontal on the right side of each light and slope upwards on the left hand side of each light. Get into the car and slowly reverse approximately another metre. The horizontal section of each light should drop slightly as you reverse, if it doesn't the headlight is set too high. It is only a rough way of setting the lights, but would ensure you don't fail the MOT.
As they are HID's I don't know for sure if the light spread will still be 100% the same, but you should still be able to ensure that they aren't directed too high.
As for removal - You need someone to post who's had them on :happy2:
EDIT... The adjuster screws are quite awkwardly placed and you may need a stubby screwdriver to get in there :happy2:
« Last Edit: July 25, 2011, 08:01:19 pm by Hurdy »
