Author Topic: Decat DP - GT PD140  (Read 13410 times)
Offline vRS_Pagey
  • -Receive: 59
Decat DP - GT PD140
« on: July 25, 2011, 07:36:15 pm »
Hearing good things about upgrading downpipes on the TDi, most of the info is about Decats though, obviously an MOT failure on a petrol but what's the rule on diseasals?
Offline mk5craig
Re: Decat DP - GT PD140
« Reply #1 on: July 26, 2011, 10:27:23 pm »
Diesels will pass mot's without a cat,
« Reply #2 on: July 26, 2011, 10:42:18 pm »
For now the soot chucker doesn't need a cat as the MOT but I read that the new laws that are coming in,any car fitted with a cat that is made after 2008 have to have it fitted
Offline vRS_Pagey
  • -Receive: 59
« Reply #3 on: July 27, 2011, 06:04:40 pm »
I love my MY2007 Golf GT even more now!  :innocent:
Offline ianc1990
« Reply #4 on: September 04, 2011, 04:53:13 pm »
I was also worried about this.
Had an mot the other day (so thats re-mapped from a 105 to 170) and also a decat.
Got a rating of 0.44 (and I beleive it needs to be under 3.5 to pass)
« Reply #5 on: September 04, 2011, 05:51:37 pm »
Surely if you keep oem cat swapping once a year isnt too much bother, if need be?
Offline vRS_Pagey
  • -Receive: 59
« Reply #6 on: September 06, 2011, 07:36:07 pm »
Hmmm, thats interesting.  What de-cat are you running mate?
I have thought about this on the vRS, but it seems that it's not a problem on the diseasel.   :happy2:
Offline will130787
« Reply #7 on: September 06, 2011, 08:28:26 pm »
Rightly enough the diseasel won't need a cat to pass mot if  registered before 2008 :happy2:
Offline ianc1990
« Reply #8 on: September 06, 2011, 10:38:30 pm »
It was just a custom stainless steel pipe.
The cat was cut out and the pipe welded in place....rather then a full downpipe but its essentially the same thing! (unless you get bigger downpipe but this still doesnt cause a failure in MOT)
Offline 81lly
« Reply #9 on: September 06, 2011, 10:42:53 pm »
When I got my Milltek downpipe I wanted the sports cat but I was told Milltek only do a decat for the diesel and that it will pass an MOT with no problem  :happy2:
Offline vRS_Pagey
  • -Receive: 59
« Reply #10 on: September 07, 2011, 10:31:11 am »
This was also an option I looked at for the vRS, but like Sy and Hurdy did, I would have the delete pipe and cat fitted with flanges so they could be changed with ease at MOT time.  Obviously with this not being an issue on the Golf, I may get my mechanic to do it when he fits the new back box.   :happy2:
Am I right in thinking this will effectively take the car to stage 2 (as with petrol) and as such will require a modification to the remap to eliminate CEL for lamba sensors etc??
Offline four!
« Reply #11 on: September 07, 2011, 04:58:42 pm »
Hi mate,
The basic diesel emissions test involves testing the amount of smoke not co, often by shining a light through it and measuring what makes it through.
The de cat shouldnt put any lights on as its not a proper closed loop system and has nothing to monitor the other side. eg petrol appliations the first sensor makes sure the lambda is good and the second, after the cat checks the cat has done its job. If you see what I mean  :happy2:
Im also thinking of the decat for my gt. I have come across 2 off the shelf options, milltek or THS. The milltek is left  63.5mm at the end wheras the THS includes adaptors to take it down to the 2 available sizes of centre section if need be. The THS is significantly cheaper and quality looks just as good but nowhere has any  :surprised:
TBH I doubt there is much changed on the map for this. Maybe a good question for your mapper, I also wouldn't mind knowing what they change.
Offline vRS_Pagey
  • -Receive: 59
« Reply #12 on: September 07, 2011, 05:35:23 pm »
Thanks for that mate, I will fire off the question to my tuner later and give you the heads up on the response.  If you come across a supplier for the THS De-cat let me know, and out of interest what sort of money are we talking?
Offline daz_pd
  • My VRS
« Reply #13 on: September 08, 2011, 08:35:15 pm »
also interested in that info!
Offline four!
« Reply #14 on: September 08, 2011, 09:29:11 pm »
THS all seem to be £145 but can't find anywhwere which has any stock  :sad1:
http://www.thsperformance.co.uk/category/Downpipes_Decats,b.html
Cheapest I have found on Milltek is from jabba sport.
http://www.jabbasport.com/store/index.php?app=gbu0&ns=prodshow&ref=MSAU282
