Author Topic: Sy's vRS APR/LOBA Hybrid - Now replaced with a proper car!  (Read 148961 times)
Offline damoegan
Re: JannerSy's Mk2 Fabia vRS 1.4TSI Update: Shark map off, jabba map on
« Reply #150 on: February 04, 2012, 10:29:02 am »
Bit of a typoi in there Sy, you have put on the top of the Jabba graph that they used 2.3bar of boost  :booty:
Offline Janner_Sy
  • -Receive: 113
« Reply #151 on: February 04, 2012, 10:29:50 am »
Just been pointed out on t'other forum.  I was merely talking of absolute pressure there  :P
Offline chungster
« Reply #152 on: February 04, 2012, 05:38:07 pm »
You started a thread on this XDS remap from weak to strong? I'd like to know more!
Cheers  :happy2:
Offline Janner_Sy
  • -Receive: 113
« Reply #153 on: February 04, 2012, 05:43:09 pm »
Yank forums
Quote
http://www.golfmk6.com/forums/showthread.php?t=25039
I just want to share what I found yesterday when playing with VCDS software.
Maybe it will be helpful for some of you guys. Mostly for those who track their cars and want less electronic assist. I'm not encouraging anyone to change the stock settings, so if you want to change something proceed at your own risk.
In VCDS Select Control Module, go to 03 ABS Brakes, then 10 Adaptation, go to Channel:
Channel 09 Brake Assist
There are 3 settings for this
0-center (stock setting)
1-small
2-hard
I tasted this one and finally locked it in value 2. I think the brake pedal and the whole system are more sensitive. My car was not braking any better but I did not have to push down the brake pedal as low as before and as hard as before to start braking.
Channel 36 XDS
1-weak
2-strong
Channel 54 DSR
0-strong (stock setting)
1-center
2-weak
Channel 58 Hill Hold Assist
0-normal
1-early (start with low RPM's)
2-late (start with high RPM's and slipping clutch)
Channel 89 ASR
Two settings
1-on (stock setting)
2-off
I tried to turn it off, the new setting was saved but after I disconnected and connected the vag com cable to check it out it was set back to value 1-“on” . So, I think it's not possible to turn it off with the VCDS software.
Channel 90 ESP
Two settings
2-off
The same thing as with the ASR. I was able to turn it off but it was set back to “on” setting after disconnecting and connecting the vag com cable.
Channel 91 Automatic, ESP switch on, Speed
There are 4 boxes 1-Automatic, 2-ESP switch on, 3-Speed, 4-Deactivated (this setting can be changed)
Boxes 1 to 3 describe probably condition which are already programmed
Two settings
0-Deactivated (stock setting)
1-Enabled
Offline damoegan
« Reply #154 on: February 04, 2012, 09:58:35 pm »
....I was merely talking of absolute pressure there  :P
Yea, righ  :laugh:
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
« Reply #155 on: February 08, 2012, 07:21:17 pm »
So why have APR got your car for 2 weeks then Sy??  :popcornsoda:
#1493
Offline Janner_Sy
  • -Receive: 113
« Reply #156 on: February 08, 2012, 07:22:48 pm »
it involves shiny new parts, new maps and a faster car.  This might all go to rat sh1t still though, parts are ordered, cars booked in, just need to hope for no setbacks
« Reply #157 on: February 08, 2012, 07:29:12 pm »
Im suddenly hankering for the homomobiles better looking cousin  :scared:
Offline Janner_Sy
  • -Receive: 113
« Reply #158 on: February 08, 2012, 07:30:22 pm »
what the Octavia.... :innocent:
You watch parts of my engine start to bend  :scared:
« Reply #159 on: February 08, 2012, 07:31:44 pm »
Polo.
Im thinking about Rods more lately.  Need a linear throttle to control the extra boost so things dont start to bend  :scared:
Offline Janner_Sy
  • -Receive: 113
« Reply #160 on: February 08, 2012, 07:32:38 pm »
it wont have linear throttle yet  :ashamed:
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
« Reply #161 on: February 08, 2012, 07:47:34 pm »
How come? Not happy with the Jabba map?
#1493
Offline Janner_Sy
  • -Receive: 113
« Reply #162 on: February 08, 2012, 07:54:26 pm »
very very happy withthe jabba map, but APR made a series of offers i couldnt turn down.
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #163 on: February 08, 2012, 07:59:31 pm »
Bukkake Party followed by a Rectal Root in the back seat?? :evilgrin:
« Reply #164 on: February 08, 2012, 08:01:12 pm »
 :signLOL:
