Author Topic: Sy's vRS APR/LOBA Hybrid - Now replaced with a proper car!  (Read 149079 times)
Re: Sy's vRS APR/LOBA Hybrid - The car is back home finally!!
« Reply #465 on: December 20, 2012, 01:08:27 pm »
With such a low deviation in compression I wouldn't worry too much.
The worst that could happen if there is any cylinder bore scoring is that they will bed in, damage the piston seals and you'll need new rings quicker due to oil usage going up.
Offline rex
  • -Given: 50
  • -Receive: 74
« Reply #466 on: December 20, 2012, 01:28:14 pm »
Your pictures bring back bad memories:
What is your compression for each cylinder. As far as I know VW allows for up to 3 bar difference between cylinders.
Offline Janner_Sy
  • -Receive: 113
« Reply #467 on: December 20, 2012, 02:21:58 pm »
between 184 and 185PSI.  VW aloy 10% difference so 18PSI  :surprised:
Just changed the brake pads on the car.
First thoughts....Tarox brakes dont wear evenly, and the DS2500 crumbles when too hot.  On of the pads has probably 75% of the pad material missing  :surprised: . On a positive mod, they are the easiest brakes i have ever had to change a pad on.
Now running Mintex M1144 pads.
Offline heavyd
  • -Receive: 29
« Reply #468 on: December 20, 2012, 07:26:17 pm »
Just read this sy :surprised:
Glad to see you got your car back in the end, now get it sold!
Offline Janner_Sy
  • -Receive: 113
« Reply #469 on: December 20, 2012, 07:28:08 pm »
I need to before i end up replacing you with the nightmare car.
Offline Poverty
  • -Given: 36
  • -Receive: 21
« Reply #470 on: December 20, 2012, 07:32:10 pm »
I rate the mintex pads, I run the m1155's and they work very well  :happy2:
Offline gazbutS3
« Reply #471 on: December 20, 2012, 07:34:06 pm »
A faulty/broken ring could cause that damage to the piston, I reckon  :smiley:
Glad to see things are back together mate :happy2:
Offline heavyd
  • -Receive: 29
« Reply #472 on: December 20, 2012, 07:37:09 pm »
Youre catching up mind :laugh:
Offline Janner_Sy
  • -Receive: 113
« Reply #473 on: December 20, 2012, 07:37:49 pm »
I wanted DS3000 but needed pads urgently so M1144s filled the void.  Next pad will be a more track orientated one.
Nooooooooooooooooooooooooooooooooooooooooooo  :rolleye:
Offline Poverty
  • -Given: 36
  • -Receive: 21
« Reply #474 on: December 20, 2012, 07:42:36 pm »
m1155 would work well on a car of your weight it seems going by hillclimb reviews
Offline Janner_Sy
  • -Receive: 113
« Reply #475 on: December 20, 2012, 07:45:05 pm »
 :drinking:
Ill look into them for the next time.
« Reply #476 on: December 20, 2012, 09:55:36 pm »
At least you knew yours could be good. This is uncharted waters for Sy.  :grin:
Offline Janner_Sy
  • -Receive: 113
« Reply #477 on: December 20, 2012, 10:07:15 pm »
Driving it this last couple days, its an absolute peach now.  Great package
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #478 on: December 21, 2012, 12:29:42 pm »
So what is the spec now, and whats changed to prevent it happening again? (or just built/apped properly?)
Diesel Daily Hack.
Offline Janner_Sy
  • -Receive: 113
« Reply #479 on: December 21, 2012, 05:02:25 pm »
The full spec is as below:
APR Stage 3 with Stock, 95, 98 and 98+ Meth programs, as well as security lockout & fault code erase.
LOBA LO270 Turbo
Wossner Pistons (OEM CR)
Pace Products Intercooler
Pace Products Radiator
VWR (ITG) intake
VWR (Miltek) 200 cell downpipe with stock cat back.
Okada plasma coilpacks
BKR8EIX spark plugs
Devils Own water methanol Injection
VWR Springs
Superpro poly bushed chassis
H&R front and rear ARBs
Tarox 6 Pot 323mm brakes with Mintex M1144 pads
TD1.2 alloys wrapped in Federal 595RSR tyres.
The piston issue should be resolved now that were running a stronger design.  Evidently the misfire wasnt a result of the low compression, so if changing the valve springs turn out to not be the source of the problem then the coice is keep the stage 3 running lower boost to the redline, or revert back to the stock turbo and keep the car at stage 2 instead.
