Author Topic: Sy's vRS APR/LOBA Hybrid - Now replaced with a proper car!  (Read 149032 times)
Offline Janner_Sy
  • -Receive: 113
Re: Sy's vRS APR/LOBA Hybrid - The car is back home finally!!
« Reply #510 on: December 30, 2012, 07:00:23 pm »
I suppose how well a pad works will be dependent on lots such as the weight of the car, brake bias, type of discs( 1 or 2 piece) cooling etc.
Im sure if i had 2 piece discs and some cooling ducts the M1144s probably would have been much better than what they were.
The bias on mine is practically all on the front, the rears are like milk bottle tops (232mm iirc).  Think i read somewhere something like 85% front bias on the brakes.    Plus the XDS uses the brakes to imitate(poorly) a LSD which will also compound the issue.
« Reply #511 on: December 30, 2012, 07:02:53 pm »
Just change the pads out when you do track days, it is only a half hour job. Then you get the best of both worlds.  :happy2:
Offline tony_danza
  • -Receive: 112
« Reply #512 on: December 30, 2012, 08:15:06 pm »
Cooking pads (which you have certainly done) affects them in different ways, some melt onto the discs, some turn to coal and break up. The key is to try and work out what operating range your stoppers have and then buy a pad to suit... Or, get some cooling sorted.
That Clio 200 I had only had 4 pot Brembos and 312s, and the would stop all day on track. I'm guessing your car is lighter too? You've got the hardware, you just have to make them work right.
There's temp paint or see if someone will lend you an infra red temp gauge for a day.
Personally with how cheap solid discs are these days, I'd get some aggressive pads and let them eat as many discs as they like - rather than then ruin pads or have sh*t performance.
I've used Carbotech, PF, Pagid and Carbon Lorraine. Non are cheap, but if you want to play - you've gotta pay!
« Last Edit: December 30, 2012, 08:22:18 pm by tony_danza »
Sideways yo!
Offline Janner_Sy
  • -Receive: 113
« Reply #513 on: December 30, 2012, 08:43:34 pm »
That Clio 200 I had only had 4 pot Brembos and 312s, and the would stop all day on track. I'm guessing your car is lighter too? You've got the hardware, you just have to make them work right.  There's temp paint or see if someone will lend you an infra red temp gauge for a day.
its 1220kg with me in the car.  Normally I go to trackdays with a friend as well, and always leave the interior in so potentially 1300kg full laden.
An IR temp gauge will be a good idea.  Where would i take the temperatures; disc, caliper or pad?
The annoying thing with mine is at the moment i am limited to the Tarox discs which obviously have Tarox tax applied to them.  I know the caliper uses the pads from a Mk2 Leon Cupra R, so thats fine for aftermarket setup, but Tarox wont tell me what discs they are so i cant look elsewhere for discs.
Offline tony_danza
  • -Receive: 112
« Reply #514 on: December 30, 2012, 08:55:16 pm »
Ah, I forgot you had that setup. Very annoying. Remind me what size the discs are?
Sideways yo!
Offline Janner_Sy
  • -Receive: 113
« Reply #515 on: December 30, 2012, 09:00:27 pm »
Polo 6R KMVW0986 B30 6 Pot kit.
Discs are 323x28mm Tarox disc code: 0214M
[pdf]http://docs.tarox.com/brake-kits-catalogue/volkswagen.pdf[/pdf]
edit
Never looked into the codes before
just seen the Cupra R 1.8 Turbo 20v (18" wheels) discs have the code 0214 but has no "m" on it.  its 323x28mm though, not sure what the "m" stands for though.
« Last Edit: December 30, 2012, 09:04:38 pm by Janner_Sy »
Offline damoegan
« Reply #516 on: December 30, 2012, 09:41:59 pm »
I was just about to say that those are the same size as mk1 LCR discs..
Just need to check PCD's. Could always get them re drilled  :wink:
Offline Janner_Sy
  • -Receive: 113
« Reply #517 on: December 30, 2012, 09:46:52 pm »
PCD?
Offline damoegan
« Reply #518 on: December 30, 2012, 09:48:42 pm »
Bolt holes on the discs. Same as wheel PCD..
Offline Janner_Sy
  • -Receive: 113
« Reply #519 on: December 30, 2012, 09:50:35 pm »
5x100
Offline tony_danza
  • -Receive: 112
« Reply #520 on: December 30, 2012, 09:54:14 pm »
First thing I thought, MKI Cupra R discs. Same size and 5x100.
We may have a plan!!!
Sideways yo!
Offline Janner_Sy
  • -Receive: 113
« Reply #521 on: December 30, 2012, 09:56:17 pm »
Do they have an offset measurement?  If my carriers are different the central point of the caliper might not match the disc.  Things are looking good though.  This will save loads of dollar on discs.  Wonder if DaveB has 2 piece 323mm cupra discs.... :grin:
Offline chungster
« Reply #522 on: December 30, 2012, 09:58:50 pm »
Badger5 Bill can do AP 2 piece discs in 330x28 spec 5x100 and caliper spacers to push them out enough to accommodate the slightly larger disc
Could be worth asking him??
Offline Janner_Sy
  • -Receive: 113
« Reply #523 on: December 30, 2012, 10:01:20 pm »
with the extra disc diameter will the discs not just end up with a ring of rust where the pad isnt covering the whole discs face which will then become a lip?
« Last Edit: December 30, 2012, 10:09:17 pm by Janner_Sy »
Offline tony_danza
  • -Receive: 112
« Reply #524 on: December 30, 2012, 10:13:10 pm »
It's a mm more that it usually sweeps, it won't make a difference.
Sideways yo!
