Poll
can i link a sub to standard h/u
yes if so how ?
3 (75%)
no
1 (25%)
Total Members Voted: 4
Author Topic: cheap easy upgrade help  (Read 1304 times)
xxtigertimxx
« on: July 27, 2011, 09:03:12 pm »
ive got a ed30 07plate not 100% sure what headunit i has init!!!
as stated i just want a cheap temp fix!!!
how can i up grade the ipod dock due to only accept the old ipods and can i link a sub to the standard system!!
Offline jaycue2u
Re: cheap easy upgrade help
« Reply #1 on: July 28, 2011, 12:18:25 am »
Cant you look in the paper work and see what HU is fitted?
Offline GLIDN
« Reply #2 on: July 28, 2011, 07:16:36 am »
You will more than likely require a Radio and MDI kit upgrade. To fix Ipod issue.
As for adding the sub to the mix.
You can use two of the following methods.
Just amplifier by itself
http://www.arcaudio.com/productdescription_pages/amplifiers/ks-series/ks-500.1m.asp
Or this unit and you can power the front speakers and sub via a single/multiple amp.
http://www.al-eds.com/AudioControl-LC2I-p22024.html
Both units have a auto sensing in the sound, so remote wire will not be required. But the connect to and from the Speaker cables still need to be installed.
Then go from there for sub duty or amp and sub duty.
