Author Topic: Brake confusion  (Read 2699 times)
Offline rex
  • -Given: 50
  • -Receive: 74
Re: Brake confusion
« Reply #15 on: July 30, 2011, 09:41:07 pm »
As I know my previous rear discs were 256mm. I am not sure if 256mm and 255mm are the same or not.
« Last Edit: July 30, 2011, 09:49:53 pm by rex »
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
Re: Brake confusion
« Reply #16 on: July 30, 2011, 10:11:34 pm »
It's my understanding that FWD cars have 255, and the 4-motion 260.
right  :happy2:
"You get what you pay for."
Offline vRS_Pagey
  • -Receive: 59
Re: Brake confusion
« Reply #17 on: July 31, 2011, 10:57:54 am »
right  :happy2:
In that case, mine will be 255mm, right?
While I'm at it, perhaps I should confirm what size I need for the fronts, although my plan is to upgrade them to 312mm.  :happy2:
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
Re: Brake confusion
« Reply #18 on: July 31, 2011, 01:41:43 pm »
No. Your RS has 286 x 12 on rear as the GTI has.
The smaller ones do have 255/256 x 10.
Offline vRS_Pagey
  • -Receive: 59
Re: Brake confusion
« Reply #19 on: July 31, 2011, 04:37:04 pm »
I'm not after brakes for the vRS, it's Swmbo's GT that I need to change................
I think maybe I need to change my user name or signature to avoid confusion!  :laugh:
Offline vRS_Pagey
  • -Receive: 59
Re: Brake confusion
« Reply #20 on: July 31, 2011, 05:07:09 pm »
Just browsing the DPM website and it seems that 'the bruce' was correct, the 2.0 TD (140) uses 255mm on the rear, the 4 motion is 260mm and the 2.0 TD (170) is 286mm - the same as a GTi - although they do list either 280mm or 288mm for the front?!?
I was looking at these - http://www.dcperformance.co.uk/cheap/129996/volkswagen/ebc-standard-rear-brake-discs/d1283.html coupled with this - http://www.dcperformance.co.uk/cheap/107094/volkswagen/ebc-oem-rear-brake-pads/dp1497.html
Any opinions?
« Last Edit: July 31, 2011, 05:09:45 pm by vRS_Pagey »
Offline vRS_Pagey
  • -Receive: 59
Re: Brake confusion
« Reply #21 on: July 31, 2011, 07:38:25 pm »
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
Re: Brake confusion
« Reply #22 on: July 31, 2011, 08:28:12 pm »
You don't need to change your user name, you just need to write clearly.
Offline alackofspeed
  • -Receive: 24
Re: Brake confusion
« Reply #23 on: July 31, 2011, 09:56:49 pm »
Is there a year when the PD170 GT changed to the larger rear discs, as a colleague's 170 PD 2007MY GT has 255mm rear discs, and 312mm fronts.
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
Re: Brake confusion
« Reply #24 on: July 31, 2011, 10:05:02 pm »
No, the 170 HP Golfs do NOT have the larger rear discs.  :wink:
It's the same as all smaller variants: 255 mm (260 mm 4-motion).
The heavier Golf Variant, Octavia, Passat or Touran are a different
thing.
Don't get fooled by some stupid internet shops where you only find
the right parts regarding PR-numbers.
Offline vRS_Pagey
  • -Receive: 59
Re: Brake confusion
« Reply #25 on: July 31, 2011, 10:24:56 pm »
I'm sorry I thought it was obvious from the op and additional links that I wasn't talking about my car.
« Last Edit: July 31, 2011, 10:46:15 pm by vRS_Pagey »
Offline vRS_Pagey
  • -Receive: 59
Re: Brake confusion
« Reply #26 on: August 01, 2011, 09:14:27 am »
Just had an email from the seller of these discs and pads - http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=280686654656&ssPageName=ADME:X:RTQ:GB:1123
They claim they're are Bosch, which are good as OE.....they seem very cheap though!
