Author Topic: Should I hear a noise from my dv?  (Read 1071 times)
Offline m4t_lee
« on: August 01, 2011, 06:57:56 pm »
I read about people noticing a tshhhhhh sound from the dv, mine I'm sure doesn't make any noise, when I accelerate I hear the turbo whistle, if I let off the accelerator I still hear the turbo whistling, when I depress the clutch is just spools down, is this right or should it be doing something else?
Cheers guys,
Mat
06 Shadow Blue GTI
Offline vRS_Pagey
  • -Receive: 59
Re: Should I hear a noise from my dv?
« Reply #1 on: August 01, 2011, 08:09:11 pm »
I have an EVOMs fitted and a stage 1 remap, under acceleration I hear the intake sucking in air and the turbo whistle, when I lift off there is a sound similar to a dump valve but I think that is the wastegate expelling air???  AFAIK the DV fitted to the TFSi engine is the recirculating type so it shouldn't make any noise.
HTH, Lee.
« Last Edit: August 02, 2011, 12:30:59 am by vRS_Pagey »
Offline swgti
  • -Given: 28
« Reply #2 on: August 01, 2011, 08:31:16 pm »
I get a little hiss which is sometimes louder than others. Generally notice it more if I'm giving it a pasting.
Offline ub7rm
  • -Given: 35
  • -Receive: 43
« Reply #3 on: August 01, 2011, 08:47:47 pm »
The DV's found on the early GTI's, 05 plate like mine, make a nice little 'sneeze' when you let off.  Its very subtle but there.  Later diaphram type DV's didn't do this and I understand the piston types don't either.
Sepang Blue S4 BE Avant
Offline T J Hooker
« Reply #4 on: August 19, 2011, 11:17:58 pm »
You'll hear it more with an aftermarket intake.
As said above my 2005 DSG made a slight hiss on lift off, but now makes a loud blow off sound with my forge twintake. Not to everyones taste I must admit. I'm still a little uncertain myself if it sounds to "boy racerish". It made a good bhp difference with my custom map though.
2005 Mk5 GTi DSG, TDR Performance Custom Map, Forge Twintake, Yellow Lamin-X Fog Light Tints, H&R Cup Kit, R32 Rear Lights, BSH Stage 1 PCV Fix.
239.8bhp / 255.8 ftlb
