Author Topic: ElsaWin Script Error  (Read 10330 times)
Offline Norbreck21a
« on: August 02, 2011, 02:54:43 pm »
HI Guys,
Had my copy of Elsawin working fine for some time now. I've just gone back into it for the first time in a couple of months, and whilst it loads OK, when I go to the Wiring diagram section, I'm getting the following error :
All I get on screen is a place holder with a red "X" in the top left corner. Not sure if another piece of software is interfering with it, as it was definately working 2 months ago, but I'm not sure where to start ?
Anyone any ideas please ?
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
Re: ElsaWin Script Error
« Reply #1 on: August 02, 2011, 04:04:00 pm »
Have you removed the SVG Viewer? That's normally the reason why that happens.
Just re-install SVG Viewer and that should solve the problem. :happy2:
Unless of course you have deleted all the data  :scared: :evilgrin:
Offline Norbreck21a
« Reply #2 on: August 03, 2011, 09:57:12 am »
You Sir are a genius. Worked perfectly, many thanks Carl  :happy2:
Offline Cupra R
  • -Given: 18
« Reply #3 on: September 27, 2011, 08:32:29 pm »
Guys, how can I reinstall this SVG viewer you speak of?  I'm getting the exact same problem.
Not done anything though, to my knowledge  :signLOL:
Laymans terms please  :laugh:
Scrub that, sorted it  :happy2:
« Last Edit: September 27, 2011, 09:03:50 pm by Cupra R »
Offline claudiusorint
« Reply #4 on: November 05, 2011, 09:05:21 pm »
I hope that in the mean time you solved the issue.
If not, just write down on Google "adobe svg" and you will find it.
Before installation, go to "Control Panel", "Add or Remove Software" and be sure SVG is not there anymore.
