Author Topic: Charcoal canister pipe assembly.  (Read 5936 times)
h4rdy
« on: August 03, 2011, 04:06:43 pm »
Anybody with ETKA know if this comes complete.
I broke it!
Thanks.
Offline martziniuk
Re: Charcoal canister pipe assembly.
« Reply #1 on: August 03, 2011, 06:41:02 pm »
When I replaced my canister it came with it. I still have my old canister and pipe too if it can't be bought separate and you want it.
h4rdy
« Reply #2 on: August 03, 2011, 07:08:13 pm »
I'll be interested in the pipe.
Why did you replace yours.
Offline theo
« Reply #3 on: August 03, 2011, 07:25:45 pm »
IIRC it comes as a complete part. JKM replaced mine back in June. Think it was about £12 or so for the part.
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #4 on: August 03, 2011, 07:53:21 pm »
Yes it does. They are £9 odd from a dealer as I have replaced them before.
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #5 on: August 03, 2011, 08:03:51 pm »
Here you go
Cost
h4rdy
« Reply #6 on: August 03, 2011, 08:34:22 pm »
Many thanks.
Offline martziniuk
« Reply #7 on: August 03, 2011, 10:20:50 pm »
If you can get the pipe you're sorted  :happy2:
I replaced my canister because of an EVAP fault code where over filling causes the charcoal canister to fail.
« Last Edit: August 03, 2011, 10:34:07 pm by martziniuk »
« Reply #8 on: August 03, 2011, 10:34:12 pm »
Over-filling as in filling your petrol tank to the brim?
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #9 on: August 03, 2011, 10:53:17 pm »
Yes if you brim the tank it will ruin the charcoal canister.
« Reply #10 on: August 04, 2011, 09:29:29 am »
Thanks given, didn't know that.
Do this at the last fuel stop in Germany to squeeze as much tax free fuel in for the drive to England
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #11 on: August 04, 2011, 09:38:29 am »
I used to do the same thing (usually at Wankum). But when i got the EVAP fault i replaced the breather line (twice) and in the end was told i needed a new cannister as it was kaput due to brimming the tank.
« Reply #12 on: August 04, 2011, 09:46:15 am »
Same, wankum   :grin:
Offline TonyZed
« Reply #13 on: August 04, 2011, 03:53:10 pm »
I wish I'd known this. I often "brim" the tank!! :ashamed:
What are the symptoms of a problem, or is it just if it shows an error code?
TonyZ
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #14 on: August 04, 2011, 04:20:08 pm »
No symptoms till you get the light on the dash. However a scan with VCDS will reveal an EVAP fault. Can't remember the exact wording but something along lines EVAP Emission control malfunction :happy2:
