Author Topic: Charcoal canister pipe assembly.  (Read 6139 times)
Offline martziniuk
Re: Charcoal canister pipe assembly.
« Reply #15 on: August 04, 2011, 06:40:52 pm »
The previous owner of mine must have brimmed the tank regularly so I just replaced the canister and now fill to the first pump click.
Offline Bo!
« Reply #16 on: December 18, 2018, 08:03:53 pm »
Any ideas what the part number is for item 3 in the diagram can’t find it anywhere.
Offline v4rley
  • -Receive: 104
« Reply #17 on: December 18, 2018, 08:20:03 pm »
I cannot either, I just looked at the one on the car and no luck as it’s seems to have worn off.
« Reply #18 on: December 19, 2018, 12:35:36 pm »
Worn off on mine too.  It's on a different EKTA diagram, probably the intake manifold.
Offline v4rley
  • -Receive: 104
« Reply #19 on: December 19, 2018, 12:43:48 pm »
1K0 133 366 BB
Offline DBXdarkangel
  • -Given: 18
« Reply #20 on: December 19, 2018, 02:14:38 pm »
I changed my charcoal canister because of the vcds scan fault and changed the selenoid and guess what? Still got the fault code and no symptoms.
Offline Bo!
« Reply #21 on: December 19, 2018, 02:33:27 pm »
Thanks for the part number v4rley.
unfortunately for me it’s been diagnosed as a leaky injector seal on number 1, not the hose.
ZemHoopoke
« Reply #22 on: December 28, 2018, 02:14:43 pm »
Looks like the pipe might have been in a bind from the position it is in now that is if it is still bolted to the motor in that picture.
Offline Ads22
« Reply #23 on: December 29, 2018, 04:33:17 pm »
Mines also now producing a fault code for this. How do you determine if its definately charcoal canister or leaky injector? If this is also left for a prolonged amount of is there any potential damage that can be caused.
