Author Topic: Engine fans working over time....?  (Read 1186 times)
Offline janus909GTI
« on: August 03, 2011, 06:04:21 pm »
im not quite sure whats wrong with it, but over the last couple of days whilst in traffic i can hear the engine fans or something working away and when i park up and turn the enginge off they are still going for a bit? does anyone know why this may be, i can only put it down to the hot(ish) weather at the moment???!!
is it anything to worry about...
its quite irritating
Offline Richn83
  • -Given: 49
  • -Receive: 85
Re: Engine fans working over time....?
« Reply #1 on: August 03, 2011, 08:11:51 pm »
Its likely just to be the increase in ambient temps mate, only other thing worth checking is that both fans are coming on (small and large fan)  It is a known fault that if the big fan fails or stops working then the small fan will take over which is potentially noisier and will run for longer.
Offline janus909GTI
« Reply #2 on: August 03, 2011, 09:31:08 pm »
ok cheers rich, will check both fans are in operation tomorrow!
