Author Topic: Cant open bonnet Help needed  (Read 1938 times)
Offline mk5craig
« on: August 03, 2011, 07:03:20 pm »
Hi all, finally get an hour to have a look over the car, tried to pop the bonnet and seems the cable has broken :fighting: and then tried taking the wheels off and find i dont have the locking wheel nut when i brought the car so not very sucessful,
Any help would be great as i had a look and you cant see much, tried pulling the plastic lever under the bonnet but does nothing
thanks craig
Offline parks
  • Red ED30 No. 1778 Detailing World member
Re: Cant open bonnet Help needed
« Reply #1 on: August 03, 2011, 07:19:16 pm »
the plastic lever under the bonnet can wear against the metal.
If the bonnet pops after pulling the lever in the car, then you just need to pull the bonnet latch/hook sideways.
Standard: Rear parking sensors, Parrot Bluetooth
Retro fitted: MFSW buttons, RCD510, Boot pop, Black Monza II, Xenons, Audi jacking points, open fog light grills.
Offline mk5craig
« Reply #2 on: August 03, 2011, 07:22:59 pm »
Thanks for your response,  nothing happens at all when pulling the catch
Offline parks
« Reply #3 on: August 03, 2011, 07:52:57 pm »
Tug the bonnet up, maybe it's not 'locked' down?
Offline mk5craig
« Reply #4 on: August 03, 2011, 08:01:16 pm »
All Sorted, took the plastic panel off that goes around the lever and the cable had pulled out of guide so put inguide and was very stiff but managed to get it open so sprayed half a can of wd40 over it so hopefully be ok now
Thanks for your help
Offline vwdubster77
« Reply #5 on: August 09, 2011, 07:51:43 am »
The cable at the coupler above the headlamp on the drivers side has probably popped out because the the cable attached to the bonnet lock is seizing.
Apparently this is a known problem.
I had this issue, in the end had to take drastic measures to get the bonnet open. Worst case being you would have to break various front end parts to get the bonnet open.
I found the cable at the lock to be totally seized. Broke it loose, re greased it etc. Good as new. Removed the lock, cable etc.
Whilst speaking to the dealer about this, its so common they carry, bonnet locks, cables etc in stock!
Regards.
Offline mk5craig
« Reply #6 on: August 09, 2011, 08:48:41 pm »
Mine still isnt 100% so do i need a new catch or just remove and clean my one?
thanks craig
Offline Thecrawf
« Reply #7 on: August 09, 2011, 10:08:45 pm »
Was gonna suggest leave it in clapham over night  :laugh:
Really do miss the mk5 Perelli rare breed of car
Audi S3 black edition 1 week old went wrong sent back to Audi
RS3 order cancelled bought C63 AMG PPP now sold after a year of expensive trips to kwik fit
New car BMW M135i loaded to the hilt
