Author Topic: Central locking  (Read 1253 times)
Offline chip20
  • -Given: 35
    • http://absolutevaletinguk.co.uk/
Central locking
« on: August 03, 2011, 08:59:07 pm »
Hi.Having a problem with passanger side locking.It won't unlock sometimes.Anyone had the same problem? If so what was the fix?
Offline LouCyffer
  • -Given: 36
  • -Receive: 63
Re: Central locking
« Reply #1 on: August 04, 2011, 07:22:10 am »
Chip, sounds like you have a faulty door lock, I've just had the same issue sorted under warranty. Your first step is a VCDS scan.
Follow my progress on http://www.mk5golfgti.co.uk/forum/index.php/topic,31476.msg390947.html#msg390947
Hope you sort it mate :happy2:
There is a risk that, left unsorted, the intermittent fault will eventually become permanent so attack it now.
« Last Edit: August 04, 2011, 10:32:59 am by LouCyffer »
Offline chip20
  • -Given: 35
Re: Central locking
« Reply #2 on: August 04, 2011, 08:58:07 pm »
Cheers mate  :happy2:
Offline LouCyffer
  • -Given: 36
  • -Receive: 63
Re: Central locking
« Reply #3 on: August 04, 2011, 09:06:03 pm »
Welcome, my friend. Give me a shout if I can help any further.
Offline ryn079
Re: Central locking
« Reply #4 on: August 04, 2011, 11:23:54 pm »
Hi I have the same identical problem in my 2008 jetta in the right rear door.  Is it something which has to to with soldering as in the mk4s?
Offline LouCyffer
  • -Given: 36
  • -Receive: 63
Re: Central locking
« Reply #5 on: August 05, 2011, 06:55:02 am »
If you read the link above, you'll find it's usually the door lock mechanism. This isn't a soldering fix, it's a replacement motor in most circumstances, and quite common. If you have warranty cover, go see your dealer, if not, see your local independent or find a breaker who has a lock mech
