Author Topic: 312mm Caliper Carrier Question.  (Read 1738 times)
Offline G-Lader
« on: August 04, 2011, 12:31:13 pm »
Hi,
Looking to make some improvements to the standard 288mm brakes fitted to the wife's GT TDi......
Does anyone know if the 312mm caliper carriers found on the Mk4 Golf / TT /S3 etc will fit onto the Mk5??
Fingers crossed it's a yes as I plan to remove all of the mods on her Mk4 1.8T shortly so would just require new discs.
Thanks!
Des.
Offline Jaywoo-GTI
  • -Given: 38
Re: 312mm Caliper Carrier Question.
« Reply #1 on: August 05, 2011, 11:32:01 am »
I belive so, I had a spare set of s3 brakes for my A3 when i first bought my golf and the caliper and carriers looked exacty the same,
Offline G-Lader
« Reply #2 on: August 05, 2011, 12:14:21 pm »
That would work out spot on if they're the same.......
I'll give them a try on the Mk5 when I remove them off the Mk4.
Thanks.
