Author Topic: Check out the condition of these valves after only 22k miles...  (Read 10730 times)
  • -Receive: 452
Offline vwrascal
Re: Check out the condition of these valves after only 22k miles...
« Reply #1 on: March 24, 2009, 07:21:58 pm »
thanks for that, im well paranoid now, ive done 24k!   :scared:   what the hell is seafoam??  engine flush?!!
Offline jonnyc
  • Herrooooo!
« Reply #2 on: March 24, 2009, 08:31:38 pm »
Big problem, as the injectors dont flush the valves, the PCV being routed back into the inlet manifold cokes the valves up really badly..
One of the big reasons I have always ran the PCV to atmosphere..
Offline cmdrfire
    • Commander Fire - my blog
« Reply #3 on: March 24, 2009, 08:51:05 pm »
US-spec engines aren't properly lean burn as well are they?
Crikey, I've done 80k, shudder to think what mine look like.
  • -Receive: 452
« Reply #4 on: March 24, 2009, 09:02:07 pm »
No, they aren't set up for stratified mode as they have high sulphur fuel.
Offline garethmk1
« Reply #5 on: March 24, 2009, 10:29:07 pm »
This is one of the trade offs of direct injection - how have you routed the PCV to atmosphere ? Do you have any pics ???
Regards,
Gareth
Mk5 Golf GTi Edition 30 No:- 2101, 3Dr, Tornado Red, Rear Tints, RCD510 & Sound Pack, Arm Rest
Mk1 Golf GTi 16v Helios Blue, Too Many Mods To List .... MY First Car ! Owned Since 1996 !!! NEARLY READY !!!!!
  • -Receive: 452
« Reply #6 on: March 24, 2009, 10:40:17 pm »
Just be aware that venting the pcv to the atmosphere as suggested will, in all likelyhood, cause you to fail the MOT emission test.
Offline garethmk1
« Reply #7 on: March 24, 2009, 10:59:05 pm »
Just reconnect for MOT ???
Any pictures of a vent to atmosphere PCV ?
Regards,
Gareth
Offline KRL
  • -Receive: 29
« Reply #8 on: March 24, 2009, 11:00:25 pm »
BSH are working on a solution.  More info here:
http://www.golfmkv.com/forums/showthread.php?t=77288
Offline cmdrfire
« Reply #9 on: March 25, 2009, 04:17:08 pm »
Vent to atmo = bad for environment, mmkay?
Offline neg
  • gone old skool
« Reply #10 on: March 25, 2009, 06:05:34 pm »
I thought BSH already did one - which Bacillus has fitted ... ?
Offline cmdrfire
« Reply #11 on: March 25, 2009, 06:08:39 pm »
That's a catch can which does not vent to atmo. This "race can" does.
  • -Receive: 452
« Reply #12 on: March 25, 2009, 07:32:17 pm »
As stated above, my setup is closed to the atmosphere.   :smiley:
« Last Edit: March 25, 2009, 07:40:31 pm by bacillus »
Offline garethmk1
« Reply #13 on: March 25, 2009, 07:38:19 pm »
Can we get some pics up ? I'm not really bothered with it venting to atmosphere - is it just a case of a bespoke filter ?
Regards,
Gareth
  • -Receive: 452
« Reply #14 on: March 25, 2009, 07:51:05 pm »
Regards,
Gareth
No, you have a new machined metal block replacing your oem pcv and hoses that go to and from the block to the can.
Here is a pic of ukdub's install.
