Author Topic: Check out the condition of these valves after only 22k miles...  (Read 9405 times)
Offline garethmk1
Re: Check out the condition of these valves after only 22k miles...
« Reply #15 on: March 25, 2009, 07:56:48 pm »
Expensive ?
Mk5 Golf GTi Edition 30 No:- 2101, 3Dr, Tornado Red, Rear Tints, RCD510 & Sound Pack, Arm Rest
Mk1 Golf GTi 16v Helios Blue, Too Many Mods To List .... MY First Car ! Owned Since 1996 !!! NEARLY READY !!!!!
Offline ukdub
« Reply #17 on: March 26, 2009, 09:43:12 am »
It is expensive for what you get, not for what is does.  Also I didn't like their catch can design so I have now fitted one of these.
http://www.forgemotorsport.co.uk/content.asp?inc=product&cat=&product=FMUNCT
Someone over this side of the pond could make something like this.  Suprised Forge don't do it.  They already have a catch can.
Maybe if enough of you lot ask, they will make something.
Laser Blue with K04 power, APR hardware controlled by REVO 2+ software
Chassis by KW V3's, Whiteline and a hint of PRO race 1.2's
Brakes by Brembo 4 pots
« Reply #18 on: March 26, 2009, 07:28:45 pm »
Do you have a pic with the new can installed?
Offline ukdub
« Reply #19 on: March 27, 2009, 05:20:26 pm »
Here you go
« Reply #20 on: March 27, 2009, 07:18:33 pm »
Cheers for that.  :happy2:
Being able to see the level of the can's content is a big plus.
« Reply #21 on: May 10, 2009, 03:32:29 pm »
That looks pretty tidy.
The only problem I can see is if the can competes for location with some aftermarket intake filters.
Offline chungster
« Reply #22 on: May 10, 2009, 03:44:26 pm »
well there's no chance of jonnyc fitting that catch can in that position in his engine bay, now that he has a monster air filter filling up that space lol.
but looks a tidy set up tho.
Offline edition_30
« Reply #23 on: May 11, 2009, 09:24:44 am »
If I wanted to vent to atmosphere would I just run 2 pipes from the valves on the block?  Is one of the valves not a return? If so then could I not just block one up?
« Reply #24 on: May 11, 2009, 09:38:23 am »
BSH are going to release a race catch can that does exactly what you are after. It's actually in the pre-order phase.
Be aware that you may not pass your emissions test in the MOT with it installed.
Offline edition_30
« Reply #25 on: May 11, 2009, 10:54:37 am »
Cool.. but im not after a can.. i was thinking of just venting to atmosphere and then return to factory fit come mot time...
Does anybody know which valve is the send and which one i can block up
« Reply #26 on: May 11, 2009, 11:51:34 pm »
I believe the race set up blocks off the port to the far left in the pic below. That port is used for allowing  the crank case pressure to be vented back into the intake.
Offline edition_30
« Reply #27 on: June 22, 2009, 11:50:50 am »
Thanks for the reply's guys... im going to order the bsh stage 2... Just a shame nobody over here sells the kit...
How often do you have to empty the can?
Also the guys in the states talk about cleaning the intake valves using sea foam... Anybody tried this?
« Reply #28 on: June 22, 2009, 01:30:38 pm »
Is this available for Leon Cupra???
**edit,  Tfsi Leon cupra.  Is this recomended?
« Last Edit: June 22, 2009, 01:54:22 pm by Tfsi_Mike »
Offline Teutonic_Tamer
  • -Given: 88
  • -Receive: 95
« Reply #29 on: October 22, 2009, 12:52:13 pm »
US-spec engines aren't properly lean burn as well are they?
No, they aren't set up for stratified mode as they have high sulphur fuel.
An they also use considerably lower spec oils, which are neither 'FSI' approved, and nor are they low SAPS.
