November 24, 2024, 08:37:39 pm
All Things Mk5
Mk5 General Area
Anyone Help My Car Will Not Start
Topic: Anyone Help My Car Will Not Start (Read 1285 times)
csmithy
Taking part
-Given: 0
-Receive: 0
August 06, 2011, 09:05:08 pm »
Ive just tryed to start my car and all it does is make a tick noice very fast and and the lights come on the dash and flash with the noice, could it be the started motor gone. can anyone help
Weston
Just look at my post count
-Given: 25
-Receive: 32
Re: Anyone Help My Car Will Not Start
Reply #1 on:
August 06, 2011, 09:09:44 pm »
Check the voltage across the battery
GTI going...
bacillus
-Given: 4
-Receive: 451
Reply #2 on:
August 06, 2011, 09:11:40 pm »
Quote from: Weston on August 06, 2011, 09:09:44 pm
Yup, sounds like your battery is flat.
LouCyffer
Won't Shut up.
-Given: 36
-Receive: 63
Reply #3 on:
August 06, 2011, 09:30:47 pm »
http://www.mk5golfgti.co.uk/forum/index.php/topic,32029.msg396198.html#msg396198
The ticking is the solenoid, it draws very little current so will still turn. Get your battery on an overnight charge if you can. If you bump or jump the car off, remember that leaving it ticking over will not draw enough current from the alternator to sufficiently recharge the battery. You need the sort of revs that normal driving produces. Go for a 20 minute drive and as long as your battery isn't knackered, it'll be ok
Last Edit: August 06, 2011, 09:35:26 pm by LouCyffer
csmithy
Taking part
-Given: 0
-Receive: 0
Reply #4 on:
August 06, 2011, 09:48:21 pm »
Just put it on charge for the night so see if it charges
All Things Mk5
Mk5 General Area
