Author Topic: Air con pressure fault  (Read 4271 times)
Offline DaveR77
    • UK-MKIVS.net
« on: August 08, 2011, 07:08:35 pm »
I've got the following fault. Googling the fault suggest that the system needed topping up but I've been to Kwik Fit who informed me it was almost full. Next step is to check the low pressure sensor, does anyone know where this is located?
Address 08: Auto HVAC
1 Fault Found:
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
Offline DaveR77
    • UK-MKIVS.net
Re: Air con pressure fault
« Reply #1 on: August 09, 2011, 10:09:46 am »
bump
« Reply #2 on: August 09, 2011, 10:15:24 am »
Only a guess but, on the pump?
Offline DaveR77
    • UK-MKIVS.net
« Reply #3 on: August 15, 2011, 08:41:19 am »
Turned out to be the high pressure switch incase anybody else comes across this fault.
£45 fitted from VW Leeds, bargain  :happy2:
