Author Topic: Still have a smelly aircon  (Read 776 times)
  • -Receive: 291
« on: August 10, 2011, 08:58:44 am »
Since the spring, I've had two blasts of Aircon cleaner, replaced the pollen filter under the glovebox and stuck in a California Scent airfreshener.
The cleaners were temporary - lasting maybe a week or so before the smell returned. The pollen filter was already cleanish but replaced it anyway.
What else can I do? It almost smells "mouldy" or "stale" and warm. If I run the A/C on, the smell disappears after a while but will return after a few minutes if I turn off the A/C.
Any ideas?
Offline LouCyffer
  • -Given: 36
  • -Receive: 63
Re: Still have a smelly aircon
« Reply #1 on: August 10, 2011, 09:40:03 am »
Sounds like you have a particularly persistent bacterial build up. First port of call is to get the car up to temp, then run the aircon as hot as possible for 10-15 minutes, longer if you can. The idea is to purge all the ducts. If this doesn't work, and neither have aircon 'bombs', I think you'll be looking at a professional service & purge.
As always, the system is prone to this if not run on a weekly basis at least, but it can happen even on more regularly run systems.
Fingers crossed you purge the pong, Stealth.
Offline ub7rm
  • -Given: 35
  • -Receive: 43
« Reply #2 on: August 10, 2011, 11:08:12 am »
Horse a tin of detol aerosol through the recic ducts (set to recirculate obviouly).
Sepang Blue S4 BE Avant
