Author Topic: Clocks / clock 'arch' removal help  (Read 772 times)
« on: August 12, 2011, 11:07:30 am »
MkII Leon Cupra but hoping it's very similar...
Currently wrestling with my clock arch...
By removing the climate panel and HU I've removed the 3 torx screws on the left side.
Still feels very stiff top left side but loose bottom left...
I'm after the 'half moon' removed for modifying.
Any tips?
Thanks in advance...
Re: Clocks / clock 'arch' removal help
« Reply #1 on: August 12, 2011, 11:14:07 am »
Cancel that, gentle persuasion...
Voila
I didn't want to risk missing a screw and snapping something. Turns out to be just the push fit clips all the way around.
Hope this helps for any virgin highline upgraders.
« Last Edit: August 12, 2011, 11:20:36 am by Tfsi_Mike »
Offline Richn83
  • -Given: 49
  • -Receive: 85
« Reply #2 on: August 12, 2011, 11:35:57 am »
while its off Mike check the part number on your cluster. see if its the same as the TDI one for sale on ebay as I reckon thats the best bet for easy(cheap ish) highline.  :happy2:
« Reply #3 on: August 12, 2011, 11:39:43 am »
I will check but can't afford a highline yet  :sad1: Need to stop the hundred quid here and there mods and save for carbon bonnet and diff :(
